how to change headlight bulb - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2006, 08:31 PM   #1 (permalink)
View twocamrys's Photo Gallery
Cool how to change headlight bulb
One of my headlights is out on my 1998 Camry. I purchased the replacement bulb but have no idea how to change it. I don't have an owner's manual and I couldn't find any information on the internet. If anyone can give me some easy to understand directions on how to change it, please post.
TWOCAMRYS
proud owner of a 1996 V6 Camry and 1998 4 cyl Camry
twocamrys is offline   Reply With Quote
Old 03-30-2006, 08:48 PM   #2 (permalink)
.::{ XwORLD }::.
View Obelix's Photo Gallery
its easy don`t worry just the drivers side one is a little hustle... i just changed mine... there is a ruber black thing it just pops out... then you disconect the wires... then there is just a little metal piece that holds the bulb.... good luck...
Gen4|Mobil 1|Michelin|K&N|93 Octane|V6|Silverstar|KYB GR-2|
Obelix is offline   Reply With Quote
Old 03-30-2006, 08:54 PM   #3 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
well i personally recommend yanking the harness off the bulb before removing the circular rubber seal (with a tab on both top and bottom). After you remove that rubber seal you will easily figure out how to remove and replace the bulb.
It is IMPORTANT that you never touch the glass of the bulb. Oils from hands are capable of shortening the life of the bulb.
nodrogkam is offline   Reply With Quote
Old 03-30-2006, 08:59 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Be sure to clean off the glass portion of the bulb with alcohol before you install it. After this, do not touch the glass, or if you do, clean the glass with alcohol.
The oils on from you hand can cause the glass to heat unevenly and cause premature failure of the bulb, or in the worst cae, the bulb will explode.
2007 Camry 2.4L 5M
Old 03-30-2006, 09:06 PM   #5 (permalink)
View yuan107's Photo Gallery
Please do what they told you. It is very easy, I did it 2 weeks ago. It just take me 5mins, that was the first time to do that. One thing you should also know is what your bulbs should be changed, high beam or low beam, because they are different in 98 camry.
yuan107 is offline   Reply With Quote
Old 03-30-2006, 09:08 PM   #6 (permalink)
nodrogkam's Avatar
sorry but 98 is still a gen 4, not gen 4.5. i own a gen 4 98 cam. The high and low are all in one.
I think in 2000 and 2001 was gen 4.5 with the separate bulbs.
http://www.sylvania.com/ConsumerProd...lacementGuide/
when in doubt ref that site.
Old 03-31-2006, 12:24 PM   #7 (permalink)
Gameroom cash: $304355
nodrogkam is correct. There is only one bulb on the 98. It should be a 9003. I just changed one on my wife's 98 a few weeks ago. It's pretty easy and the instructions you received in the previous posts should make it an easy job. It should take about 5 minutes.
Mike
Old 03-31-2006, 05:55 PM   #8 (permalink)
.::{ XwORLD }::.
yep correct i have a 99 one and everything is in one... i think the Gen4.5 and up are different .... (i didn`t touch the glass of the bulb at all but forgot to clean it with alcohol )
Old 03-31-2006, 07:20 PM   #9 (permalink)
nodrogkam's Avatar
dunt worry bout the alcohol.
Passenger headlight is dim Mins Archived Corolla threads 3 12-13-2005 12:48 PM
Question on Headlight Bulb and Alternator for a 05 Taco? deff808 2nd Generation (2005+) 20 09-01-2005 12:26 PM
Headlight installation 03ESimposter Camry & Solara Lounge 11 12-08-2004 10:41 PM
headlight bulb question hclee25 Camry & Solara Lounge 7 11-18-2004 06:22 PM
Troublesome bulb change on 2003 Corolla Perry Archived Corolla threads 7 05-12-2004 12:43 AM
