Funny Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2006, 05:04 PM   #1 (permalink)
View JaminJimi's Photo Gallery
Canada Funny Camry
89 camry v6, Car was fill with gas then wouldnt start.. Installed a new fuel pump and was ok for a day, then started to starve for fuel and quit. Took the tank back out and pump is working fine but for some reason the fuel is not reaching the motor. If I thow some fuel in the thottle body she will start. The efi 15amp fuse is fine, but there is also another fuse type of thing in the same panel, could this be the problem.. Thanks.. Jimi
JaminJimi is offline   Reply With Quote
Old 04-01-2006, 04:09 PM   #2 (permalink)
Gameroom cash: $304355
We need to know a little about the symptoms. What is it doing when it doesn't start? Do you turn the key and nothing happens?. Does the starter turn over (crank) the engine without the engine starting? Does it start and die?
That said, since you seem to be thinking fuel delivery problems, have you ever changed the fuel filter? Could it be clogged and not allowing the fuel to reach the fuel rail and injectors? Have you checked to see if the fuel pump relay is functioning? How did you check the fuel pump?
Mike
FS: Misc Gen 4 Camry parts (engine/interior/exterior) got_trd Car Parts for Sale 41 08-01-2007 03:10 PM
What are you really missing with your Camry!!! smt_007 Camry & Solara Lounge 10 02-28-2006 11:01 PM
Toyota's Camry Hybrid recipe: A little money, a lot of ideas EKam Toyota News 4 01-31-2006 01:05 PM
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 05:06 PM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
