Remote Programming Instructions. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2006, 05:22 PM   #1 (permalink)
View mclee45's Photo Gallery
Does anyone know the programming instructions for a 1994 camry remote. This is not the RS alarms. The alarm is a Audiovox Model APSBT. The alarm came with the car when bought from the dealer. Any help would be appreciated.
mclee45 is offline   Reply With Quote
Old 03-31-2006, 05:31 PM   #2 (permalink)
View extoytech's Photo Gallery
Is there a red lighted button to the left of the steering wheel
extoytech is offline   Reply With Quote
Old 03-31-2006, 05:55 PM   #3 (permalink)
yes, there is a red light and it stays lit all the time because the alarm is on valet mode. I turned it off because I do not have a remote that works to turn the alarm off. Now that I have the remotes, I need help programming them. The remote is a 1 button remote.
Old 03-31-2006, 06:12 PM   #4 (permalink)
I assume that the light is also a button. If it is then with the button in turn your ignition on and then off. then press the button so that it is out, then in out (do this quickly) if the horn honks press your remote button untill the horn honks again.
Ps this probably won't work since you have a one button remote but it can't hurt to try.
The camry was designed as a car for the masses it is not fast or flashy and therefore I will not make it that way...................................damn I need a fast car.
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
1994 camry keyless entry remote programming instructions camry528 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-20-2005 10:12 PM
94 camry keyless entry remote programming instructions amerellie 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-25-2004 11:15 AM
Keyless remote programming instructions Phil246 General Discussion 7 05-17-2004 04:43 PM
keyless remote programming instructions? geez01hghlndr Camry & Solara Lounge 3 05-01-2004 09:49 PM
