Check Engine Light Code 55 (HELP) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2006, 01:37 PM   #1 (permalink)
View Qpats's Photo Gallery
I need some help please.
A few days ago my CEL came on. Code 55. In my manual it says it is related to the knock sensor. I know I have to remove the intake plenum to get to it.
My question is, is it possible to find the connector and if so, I would like to try to disconnect it and reconnect it. Then I could maybe try to clean the connections???
I have a Camry 92, V6 SE. 183000 miles.
Where is the knock sensor located exactly? It is so cramped there it is hard to see through.
Does anybody have pictures?
Thanks again!!!
Toyota Camry V6 SE 1992
Qpats is offline   Reply With Quote
Old 04-03-2006, 08:04 PM   #2 (permalink)
Any ideas?
You have two codes in the manual...53 and 55... I wonder if the knock sensor is bad or something else is causing the problem
Old 04-03-2006, 08:44 PM   #3 (permalink)
Just trying to turbo
theman33b's Avatar
View theman33b's Photo Gallery
I believe your car has two knock sensors i believe and yes they are under the intake it takes some work to get to them autozone has a great picture of the two sensors here is the link:
http://www.autozone.com/servlet/UiBr...3d8013ebdd.jsp
Yea i know its long, heres the picture too if the link doesnt work:
Fig. 1: Some 6-cylinder engines are equipped with two knock sensors. One for each cylinder bank
theman33b is offline   Reply With Quote
Old 04-04-2006, 08:52 AM   #4 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You have to remove the plenum to get to them the picture and link that theman provided is spot on.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 05-16-2007, 12:53 PM   #5 (permalink)
Knock sensor - Please help
I have read a lot of messages where people could disconnect the wire, take a piece of sand paper and clean the connectors. Is that possible to do? If so from which side can you reach the sensor? The driver's or passenger's side? if you have small hand is it hard to reach?
I am not talking about replacing the sensor but just disconnecting it to see if the connectors are dirty. (Who knows maybe I can be lucky with this)
Thanks!
Old 05-16-2007, 06:15 PM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
it's impossible to reach the knock sensors without removing the intake plehum+manifold there is no way in at all except from the top
and there are no connectors to clean....you could try cleaning the actual sensor itself so that it can ground better on the block, but it shouldn't be able to get dirty since it's already threaded in
the only thing that usually happens on a stock engine is the wires themselves going due to age, heat, or pulling
HaHa
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Traction Light with P0135 check engine code fincobbler Solara 8 05-01-2008 07:51 AM
code P0505 CHECK ENGINE light. Andrey12 Yaris, Vitz and Echo Forum 7 05-22-2006 04:30 PM
Check Engine Light on 98 corolla 240meowth Archived Corolla threads 0 07-24-2004 05:55 AM
