question for Water Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2006, 04:00 PM   #1 (permalink)
View gbaoyn's Photo Gallery
3rd Generation question for Water Pump
I just got my new OE water pump from dealer,but I don't see any GROOVE on it.Manual says that some high temp RVT sealant should apply to the groove on all engines except 1MZ-FE engine.Mine is 92 3VZFE.The water pump came along with a gasket and 2 rings. Does anybody have any idea about it?
Thank you!
gbaoyn is offline   Reply With Quote
Old 04-02-2006, 06:43 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Are you sure, you got the right water pump for your engine?
3VZ-FE uses RTV silicone instead of a gasket.
http://autozone.com/servlet/UiBroker...3d8013e465.jsp
"Skoolin' the unlearned!"
Old 04-02-2006, 12:16 PM   #3 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
actually, they started using a gasket, i did my water pump a couple months ago, and just used shcelac and the gasket.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 04-02-2006, 12:41 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Hmm....
In that case, use the gasket along with RTV silicone.
Some may think the RTV silicone is overkill since theres a gasket. But I rather use the silicone, then have to take it back off later and seal it up if it leaks.
Old 04-02-2006, 06:38 PM   #5 (permalink)
Thank you guys, it made sense to me. Thank you again.
Walbro Fuel Pump, turbine pump? almc2242 Hardcore Tech and Competition 13 02-19-2005 09:08 PM
LS 400 no power to the fuel pump?? 70 140 General Lexus Discussion 2 02-04-2005 08:42 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
95 camry fuel pump connection questions dwmoss 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-24-2004 12:45 PM
