Originally Posted by 88 LE
^ So I take it that its leaking around the radiator hose? Where the hose mates to the thermostat housing.
If so, have you tried using a new hose clamp? In which case the hose is not sealing tight enough around the thermostat housing or the thermostat housing is cracked.
I'd pull the radiator hose off and check the thermostat housing, if you haven't already done so.
If the thermostat gasket was bad and leaking, it would most likely leak inbetween the thermostat housing and water pump housing. In other words where the thermostat housing bolts to the water pump housing.
I put the new gasket in and the leak stopped.
It took a while to burp it and I feel it is still running a tad cool.
I drove around the with the radiator unlocked for a bit and that got most of the air out. Air blows hot, but I think I can get more. Maybe the rest of the air will work itself out over time.
Thanks.
