I have a 2000 camry LE v6 with 147k miles on the clock i bought her new with 200 miles.
anyways i was leaving work yesterday and i started her up (she'd been sittin in the lot all day so the engine was cold)
so normally i start the car up when its cold and she revs a bit high until the engine warms up then the revs drop to between 600-1000 and all is well...
but yesterday i started her up cold and she dropped down to 0rpm and stalled
and kept doing that even though i had kept it reving at 2500 rpm for a few mins then put her into reverse...and i pulled her out of the spot and she stalled again
got her started revved to 2500 rpm again let off the throttle and threw her into drive and was fine till i slowed down to pull out of the lot into the main road and she stalled again...
then i started her backup and got on the main road drove for about 1/2 mile at 50mph and then stopped at a light and she was fine....and then she ran fine and started fine this morning too
now this happened once last saturday...
i change the oil every 5k miles (synthetic)
just replaced the fuel filter and plugs
going to recharge my air filter (Which i did when i replace the plugs about 10k miles ago)
and clean the throttle body tonight
now i have aproblem on warm starts when i start the car and it drops down to 300 rpm and if i put her into gear she stalls.....so before i put her into gear i rev her to 2500 rpm and she's fine...
i read some posts regarding a coolant temp sensor and a Idle Air control valve
i'm going to do some reading in my manual tonight about these two.
but any other suggestions and has anyone else had any issues like this??
i also put some berryman's in the fuel tank which i do once every month or 2...
any other suggestions/ideas would be helpful
no check engine light either yet!! but i'm going to still hook up my obd 2 reader to see if she's throwing out any codes...
thanks in advance!
