longer studs need for rims ; ; - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2006, 12:18 PM   #1 (permalink)
D_Rock27
View D_rock27's Photo Gallery
3rd Generation longer studs need for rims ; ;
my lugs dont have enough bite on the studs do to the quarter of an inch spacer, how can i solve this problem also a shop sold 1inch adapters but said it would probly bump the wheel well. just though i'd add that in there.
D_rock27 is offline   Reply With Quote
Old 04-04-2006, 12:56 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
probably going to ahve to replace all of teh studs. if you take it somewhere to have itdone it will cost you way more than what you want to pay, it can be fairly labor intensive. You can do it your self jsut go to a parts store and buy new studs taht are long enough to work for your application. you will ahve to knock out the old studs and then press the new studs in. You can use some old lug nuts to pull them in also.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 04-04-2006, 01:01 PM   #3 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
Return the rims and buy the right offset?
Hawkeye-SE is offline   Reply With Quote
Old 04-04-2006, 05:04 PM   #4 (permalink)
D_Rock27
3rd Generation
people from wheelsnext.com says they will send me a set of shank nuts to get the proper bite i need since its narrow at the insertion end and fills in the space once all the way in.
Old 04-04-2006, 09:23 PM   #5 (permalink)
View mspringer's Photo Gallery
I hope you have wheels that require shank lugs.
I'm with Hawkeye - get different rims.
mspringer is offline   Reply With Quote
Old 04-05-2006, 01:32 AM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
Go to the Toyota Dealer. Ask for a stock replacement stud, then ask if they have anything else longer. Not sure what model might actually have a longer stud, but it's worth a shot.
It likely won't be the stud for an Echo or a Corolla. Ask for Tacoma, 4-Runner studs from about the same year. You might get lucky.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 04-05-2006, 01:28 PM   #7 (permalink)
abovethelaw's Avatar
View abovethelaw's Photo Gallery
I had the same problem with my 18x8 rims with +42 offset. I had to use spacers in the rear and had to change the wheel studs for longer ones. Got longer wheel studs from BOB's TOYOTA in SoCal.
abovethelaw is offline   Reply With Quote
Old 04-06-2006, 09:22 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
those wheels center themselves on the center hole, not on the studs, get the right wheels that will bolt to the hubs
Old 04-09-2006, 08:46 PM   #9 (permalink)
Embrace the Suck
Edmo83's Avatar
iTrader Score: 8 reviews
View Edmo83's Photo Gallery
i'm trying to put on 17X8 +45 rims, im in the same boat as you D rock,
Let me know if you make any progress, i think we have a similar hub, 5 X 114.3? with around 1" or so long studs?, i think they are around the same from 3gen to 4gen
I also have 5/16" spacers, roughly 8mm....if this project gets any more complex, i might just sell the rims off
Good luck buddy
92 SC300 Garnet Red 5-speed 119k
01 Camry LE V6 Sailfin Blue 95K miles
Edmo83 is offline   Reply With Quote
longer lug studs Brando8844 T-100 0 12-12-2005 10:02 PM
STUDS.... I need longer ones. Piddy General Discussion 12 06-10-2005 01:01 AM
Longer Wheel Studs Piddy Hardcore Tech and Competition 6 04-10-2005 11:26 PM
Where can i get longer wheel studs?? augcam Camry & Solara Lounge 2 03-10-2004 09:37 AM
Longer Lug Studs for Gen 2?? spills1969 1st & 2nd Generation (1983–1986 & 1987-1991) 5 09-28-2003 12:29 PM
