how to check CEL? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2006, 08:36 PM   #1 (permalink)
View simplyxtrippin's Photo Gallery
how to check CEL?
i own a saturn, and i've seen on a saturn forum that you can find the code by sticking a clip on the OBD socket. i can't find the that particular thread. So, can i do the same to my newly acquired camry (92' v6 xle)? or do i have to go to the shop and get it checked?
simplyxtrippin is offline   Reply With Quote
Old 04-04-2006, 10:47 PM   #2 (permalink)
View 1shot1kill's Photo Gallery
well usually it would need a computer scanner thingy from a shop and it reads ur onboard computer and it tells the scanner whats wrong this and that. thats what it was in my truck.. umms.. i believe its the same on the camry too..
1shot1kill is offline   Reply With Quote
Old 04-04-2006, 11:08 PM   #3 (permalink)
i know that you can just use a scanner for the OBD, but i've heard that you can figure out the code by connecting two of the holes on the OBD socket. then you turn thr key to "ON", this'll make the CEL blink, then you can just cont it and that's the code. i know that this can be done with the OBD1 saturns, but not sure if it'll work for the camry. don't want to mess it up.
Old 04-05-2006, 06:16 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Short pins TE1 and E1 on the diagnostic connector (under the hood near the drivers side strut tower).
http://autozone.com/servlet/UiBroker...3d8013edfc.jsp
^ See the 3 sections under trouble codes.
"Skoolin' the unlearned!"
Old 04-05-2006, 09:00 AM   #5 (permalink)
awesome. just to make sure: these are safe, right?
Old 04-05-2006, 09:23 AM   #6 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
just do wut 88LE said.....i do it all the time for troubleshooting purposes
ag6286 is offline   Reply With Quote
Old 04-05-2006, 09:44 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Yes.
I've shorted TE1 and E1 on my Camry many times. As well as other Toyotas.
Old 04-05-2006, 03:29 PM   #8 (permalink)
what did u guys use to "jump" it? can i just use a paper clip or a piece of speker wires?
Old 04-05-2006, 05:18 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Paper clip works fine. Just open it up, bend it into a U, and shove the ends into the proper terminals (TE1 and E1).
You can also use a small piece of wire with the insulation stripped off the ends. I'd use solid wire though.
Old 04-18-2006, 03:28 PM   #10 (permalink)
thanks for the replies. the code is "71" which i gues is the EGR. do i have to replace the gasket when i clean it?
Old 04-29-2006, 08:59 PM   #11 (permalink)
View 97&02camryleI4's Photo Gallery
Can I use this same method for the 97 5SFE i4 camry? I got a CEL on also. Thanks.
97&02camryleI4 is offline   Reply With Quote
Old 04-29-2006, 10:45 PM   #12 (permalink)
View foompla's Photo Gallery
no.
foompla is offline   Reply With Quote
Old 04-29-2006, 11:20 PM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Your 97 is OBD II so you need to get a scanner to pull the code.
Most autopoarts stores, ie Autozone, Kragen, Pep Boys should do it free.
2007 Camry 2.4L 5M
Old 04-30-2006, 01:09 AM   #14 (permalink)
The Kragens around my area do not do it for free nor do they rent them out. They said I'd have to buy it, probably no return either. Autozone rents them out for free I think but they're always out and there's only one autozone around my area. I'm thinking of buying one but I don't want to spend too much on it (less than $100) since I won't be using it much. Which brand/model is recommended for an occasional home mechanic DIYer? Thanks.
Old 05-08-2006, 08:04 AM   #15 (permalink)
try ebay.
1995 corolla check engine light ltnflvr Archived Corolla threads 6 01-12-2007 11:23 AM
how check cel codes on 00 mrs (searched) 00mrs MR2 Forum 2 08-11-2005 09:05 PM
