Reduced engine power!!! Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2006, 08:43 AM   #1 (permalink)
View ballz2wallz's Photo Gallery
My car is really running sluggish right now and just needed some input on what you guys thought it was. I have a 94 5sfe, 115000 miles BTW.
The symptoms are:
-Reduced engine power
-battery light and rear brake light indicater light are lit on the dash
-this morning coming to work, clock was so dim I could not see it and I was practically flooring the accelerator and car would barely move...also wipers were slow as well as windows, and when turn signal was on tach and speedo needle were bouncing
-also, in the past few months, I have been getting 50 miles less per tank
I changed the coil in my distributor last winter and it started soon after that
Did I get my timing off or is my alternator just going bad???
All help would be greatly appreciated,
Ballz
ballz2wallz is offline   Reply With Quote
Old 04-06-2006, 08:53 AM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Your batters is bad or you need a new alternator. If your speedo is bouncing like that then there is defiantly not enough power to run the rest of the cars electronic systems. Just check your alternator and get a new battery.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-06-2006, 09:02 AM   #3 (permalink)
I doubt it is the battery b/c I am running a red top optima....how do I check the alternator?
Old 04-06-2006, 09:15 AM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
disconnect your battery wile the engine is running......if it stalls then you need a new alternator.
Old 04-06-2006, 09:25 AM   #5 (permalink)
Is there any possibility that the timning could be off and causing this trouble?
Thanks for the suggestion!
JS
Old 04-06-2006, 09:43 AM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
The timing would have nothing to do with the fact that your speedo wont even work with the blinkers on....it is defiantly something with the electrical system.
Old 04-06-2006, 10:43 AM   #7 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
lol your car's going to stall if that happens regardless of whether you need a new alternator or not. My car runs beautifully, with no electrical issues whatsoever, but the second that the terminal popped off my battery (shitty Chicago roads, terminal not tightened down well enough), the car stalled like nobody's business. I think it's a safety mechanism built in by Toyota.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 04-06-2006, 11:00 AM   #8 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
^^ x2
my dad was taking my car to the mechanic for me and i guess i didnt have the terminal tightened enough and it popped off while he was driving on the highway thankfully he was able to get to the shoulder. stupid mistake on my part
MrSo0h0o is offline   Reply With Quote
Old 04-06-2006, 12:10 PM   #9 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
I think he meant with the alternator disconnected
a car won't run when it has no power at all
HaHa
Old 04-06-2006, 12:31 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
yeah i meant with the alternator disconnected. That way you can see if it even runs without it. If it does the battery is good. If it doesn't the battery is shot.
Old 04-06-2006, 12:40 PM   #11 (permalink)
Moving Forward
View Cyorke's Photo Gallery
SOunds like the alternator. The ony thing wierd is you say the rear light indicaotr is on. Normally on Toyotas if the alternator goes out the battery light and the brake light will come on not the rear indicator.
Everything you are explaining sounds more like electrical problem than timing. You can take the car to jsut about any autozone or similar store and they will usually tes the alternator for free. They have equipment to hoiok up to it to test it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 04-06-2006, 03:45 PM   #12 (permalink)
View mspringer's Photo Gallery
Here is an example of what NOT to do...
Do you have a multi-tester, or a volt meter of some sort (even an old gauge will work)? Check the voltage at the battery with the car running, it should be between 13.5 and 14.2. Any less (or more) and you need a new alternator.
My money is on the alternator.
mspringer is offline   Reply With Quote
Old 04-06-2006, 05:57 PM   #13 (permalink)
The Greek....
GrkBallaG's Avatar
View GrkBallaG's Photo Gallery
^ word, thats the best and safest way.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
I need power from my 2e engine... Innocent Introduce Yourself Here 5 05-14-2008 12:00 PM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
Engine power questions Bakerboy Tercel, Paseo, Starlet, and Sera Forum 5 01-17-2006 04:51 PM
when u hook any power wire it gives the engine light? jigga99 1st Generation (2001–2007) 0 12-22-2005 12:50 PM
