Need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2006, 05:29 PM   #1 (permalink)
View i 1a 05 Camry's Photo Gallery
Need help
I just installed a K&N air filter for my gen 5.5. All of a sudden the maintenance light starts to blink when I turn the engine on. What is the problem?
i 1a 05 Camry is offline   Reply With Quote
Old 04-07-2006, 05:32 PM   #2 (permalink)
View Tarzan's Photo Gallery
Check the air sensor connection to the air filter box. When you installed the K&N, you could have knocked something loose.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 04-07-2006, 11:13 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
It has nothing to do with the air filter. You just didn't reset the light when you changed your oil. You have to reset it as stated in the manual every 4000 miles. Unless it is the orange light that looks like an engine that is is lit up. Then you need to get it scanned for codes. But if it is the maintenance required light then you just need to reset it as stated in the manual.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-08-2006, 12:27 AM   #4 (permalink)
i guess ill have to try that then
Old 04-08-2006, 12:43 AM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
you can try to reset your ecu and see if that still shows up (if it is a check engine light).
It could be the computer not liking the extra airflow, so resetting the ECU typically gets rid of it.
Disconnect your battery for about 15 minutes and re-attatch it. You will probably loose radio presets and audio settings doing this.
nodrogkam is offline   Reply With Quote
