Replace rear speakers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2006, 10:36 AM   #1 (permalink)
View caveman017's Photo Gallery
4th Generation Replace rear speakers?
Well my repair manual should be here next wed, but My left rear speaker is dead. I'm being offered a cheap pair of Jensen Triaxial 6x9" for $20 (half what circuit city sells them for) Can i just somehow hook those up to the red and black wire as it is now?
Also, how do i remove the speakers? As i said manual is coming in in a few days
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 04-08-2006, 03:18 PM   #2 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
If the gewn fours are like the gen 3 you have to pull off the third brake light. then you will have to put down the seats. Then on my car there where two philips head screws (one on each side) behind the seats. Then that back cover will pull out. The four screws to each speaker is there. I am not shore which wire goes to which termanal. But if you take a 9-v battery adn touch the positive to the positive and - to - then the speaker will move out if not then you flip them around.. So then you hooke up the speaker so that then you put the positve to one ternaml and negitive to the other the speaker will move up towards the cabin area. So bacisly what you are doing is puting all the speakers in phase.
Pimpinda93camry is offline   Reply With Quote
Old 04-08-2006, 05:50 PM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
why not get some better speakers?
go to crutchfield.com
they have good prices and if you can handle a screw driver, you can change it yourself.
Crutchfield.com will have instructions also
skewe is offline   Reply With Quote
Old 04-08-2006, 06:09 PM   #4 (permalink)
Alright i have the rear seats removed but i cant get the back/top/side paneling off, idea?
Old 04-08-2006, 08:25 PM   #5 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
Go to the audio part of TN. They say you don't even need rear speakers. Just replace your front ones with a good set and it'll sound the best. and if you want rear speakers which aren't recommended......you can move the old ones from the front to back?
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 04-08-2006, 08:35 PM   #6 (permalink)
View freestylez's Photo Gallery
Gen 4 Camrys have 6x5's in the front and 6x9's in the back
first thing u have to do is take off the brake light and the headrests on the backseats u will need to pry off the molding on the sides of the back windows and i think there are a few screws ull have to take off on the back panel once all these are loose u need to take off a few more screws that holds the speakers
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 04-08-2006, 08:50 PM   #7 (permalink)
View AmanO's Photo Gallery
I know you meant this, but they are 6.5inch in the front and 6inch by 9inch in back.
I partially agree that the back are not needed but I like having a balance. I put a 30$ set in the back which are better than stock and a 80$ set in teh front.
Theoretically the backs can get lower, and if you dont have a sub (like me) that helps.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 04-08-2006, 10:09 PM   #8 (permalink)
Alright after 3 hours I finally did it. I used stiff cardboard to create the adapter to screw it in
Old 04-08-2006, 11:46 PM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
hmmm good job! If you get really good speakers with a lot of bass u'll have my problem of rattling. Funny how after dynamating my whole rear deck i discover that it was my roof that was rattling the whole entire time....
nodrogkam is offline   Reply With Quote
Old 04-09-2006, 01:28 AM   #10 (permalink)
View 1shot1kill's Photo Gallery
wait so.. the back is not recommended?? i'm curious why?
1shot1kill is offline   Reply With Quote
Old 04-09-2006, 01:30 AM   #11 (permalink)
The Cool Guy
Check out the audio forum. You'll learn lots. It's called "imaging" i believe. Something about a rock concert or maybe a symphony hall.
Old 04-09-2006, 09:25 AM   #12 (permalink)
nodrogkam's Avatar
it's not that its not recommended...the sound is way better with aftermarket speakers, but the toyota designed speaker mounts specifically for the type of speakers they put in there and no aftermarket speaker will fit into it. So once your custom mount your speakers that are probably much more powerful you end up with a few problems.
Old 04-09-2006, 10:45 PM   #13 (permalink)
A.J. Subramaniam
View s_ajanthan's Photo Gallery
I have stock speakers in my Gen4 camry and whenever i blast the speakers with bass set high, i get really bad rattling from the back. what's causing this and what can I do to fix this without changing my audio settings
s_ajanthan is offline   Reply With Quote
Old 04-09-2006, 10:48 PM   #14 (permalink)
nodrogkam's Avatar
your bolts for the speaker mounts mayhave gotten loose. tighten them. but to do so you'll have to remove a good amount of stuff. (same procedure as removing speakers).
or perhaps your celing trim is rattinling like in my car...
sit in the back and push up on the trim and see if it stops...
Old 04-11-2006, 02:03 PM   #15 (permalink)
View Mcthings's Photo Gallery
You don't need rear speakers? I replaced my front ones, and it sounded better. But when I replaced the back ones a few weeks later, the sound was much more round and it felt more complete.
Mcthings is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Need help putting in rear speakers grill... 56k stay away heavy duty pictures lol wild2taz Audio, Video, and Security - Tech 5 06-29-2005 09:47 PM
97 Corolla rear speakers GuJu MaN 89 Archived Corolla threads 2 03-05-2005 11:29 AM
97 rolla rear speakers Robere Archived Corolla threads 2 06-10-2004 05:32 PM
I'm so mad! grrr.. damn rear speakers!! REN69 Archived Corolla threads 2 01-02-2003 10:34 PM
