Throttle body adjustment screw - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2006, 01:55 PM   #1 (permalink)
View sameer2601's Photo Gallery
4th Generation Throttle body adjustment screw
What is the exact position of the throttle body adjustment screw. i have adjusted mine in order to gain idle speed but the idle speed is back to its previous state after few minutes of driving. should the throttle be slightly opened or not opened at all at idle. btw why is that screw there of the idle is controlled by the ecu? does it make any changes to the engine if its adjusted?
97 Camry LE
I4 Automatic
130000 Miles
sameer2601 is offline   Reply With Quote
Old 04-08-2006, 08:57 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Put the screw back the way it was. The idle is computer controlled. If you change something then the computer will compensate somewhere to get the idle back to what it's supposed to be. Soon you'll be all screwed up.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Peel out after cleaning throttle body? Blackhawk3D Camry & Solara Lounge 40 04-03-2007 07:01 AM
Question with regards to the throttle body Ghost Archived Corolla threads 0 10-05-2005 03:19 PM
Throttle Body Problem? ghost99x MR2 Forum 3 10-04-2005 01:48 PM
Throttle body spacer, Anyone interrested ? mox Camry & Solara Lounge 8 08-07-2004 11:18 PM
