93 V6 LE Camry
I just changed the motor and regulator assembly because the old one was broken. Now that i have the new motor in, i connected the switch to test it out before I put it all back together, it still doesn't move.
I tried the switch on the door itself (it's the passaenger door) and nothing, then i tried the switch on the driver door and nothing. I played with it for a little bit and then it worked but only using the switch on the driver door. So started to put it together but before i got too far i tested it again and again it didn't work with any switch. What could be wrong?? Thank you in advance.
