Originally Posted by Sniperdude
I've got a gen 3 1996 camry, 5sfe engine. When I turn the car on, I get a ton of shaking from the car, plus I noticed that the engine idles at 500 rpms. I have oil leaking from underneath the engine somewhere, but I want to know what could be causing this, because the car's been sitting for 5 years, and I have no idea what's causing it.
Thanks.
- mike
It's been sitting for 5 years. Where? In a indoor garage or outside? You may have corroded spark plug wires. Check your spark plugs and spark plug wires, distributor, etc. I would recommend changing all your spark plugs.. the tips are probably all corroded.
Yes, dump out the gas. Change the fuel filter (probably clogged). The gas will probably have some water in it now. You can actually get additives to help remove water from the gas. BUT remove as much as gas possible from your tank. Then I would fill up the tank and add the additve to remove moisture from the tank.
Once you've solved the problem, you will also need to change ALL the fluids in your car. Yes, ALL the fluids. Tranny, brake, coolant, power steering, engine oil, etc. It will be costly, but I would do it.
Once all is okay and all fluids are changed, drive the car in the highway and rev the car a little harder than normal. You want to burn out any contaminates in the engine system, fuel lines, and clean out the cat, exhaust system, etc.
