Hi guys,
96 LE with 150 K .so I wanted to flush my brake system and I messed up
I started with RP took the wheel off .
I had bought a large syringe from Wallmart ,attached clear hose to it and stuck it to the bleeder and cracked the bleeder open and started pulling back on the syringe .
There were bubbles comeing out like and aquarium stone!! And this kept happening forever.then i noticed that the bleeder plug was loose i guess air was going in past the threads of the bleeder .
How much do you open the bleeder to get things moving????
I take out the drums and i noticed that it is leaking on the other side(wheel cylinder) as well.
<stupid> I presed the brake pedal and I heard a popping noise....... looks like I popped the piston out of the wheel cylinder .I move the adjusters all the wayy back in but I cannot get the drum inside!!!!!!!!!!
what did i miss??
also ,will some kind soul please tell me the size of the bolt that you use to get the drums off!!
TIA
P.S : the good part is I got the drum back and although its very tight (and runs like a dog),I got it all fixed up and it si srunning.
