Oil Change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2006, 03:28 PM   #1 (permalink)
View YYY Camry's Photo Gallery
3rd Generation Oil Change
Hi guys, do I have to change my oil every 3,000 miles? If I, do that I then have to change it every 6 weeks because I drive alot. What happens if I don't change it every 3,000 miles? What happens if I just change it every 4,000 miles? Is it a good idea to flush it? My car is over 100k miles. Thanks
YYY Camry
YYY Camry is offline   Reply With Quote
Old 04-09-2006, 07:19 PM   #2 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
relax, generally oil is rated to 5,000 miles, its just better+safer to change it earlier.
read the oil container.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 04-09-2006, 07:50 PM   #3 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
If you don't change it at EXACTLY 3K, your engine will destroy itself.
KIDDING!!!!
It's just the longer it stays in your engine, the crappier it gets. Thicker, burnt motor oil with REDUCED viscosity which INCREASES the stress on your engine, giving it more work, slowly robbing you of some MPG and a little HP/TQ. Who wants sludge motor oil in their valvetrain and crankshaft?
Lord_Anarchy is offline   Reply With Quote
Old 04-09-2006, 08:05 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Have your motor oil analyzed and they can tell you whether the oil can be run longer.
You should be safe changing it every 5000 miles or perhaps even longer. But to be sure, you should have the oil analyzed. The analysis will tell you if you can safely run the oil longer than 3 or 5 thousand miles.
2007 Camry 2.4L 5M
Old 04-09-2006, 08:17 PM   #5 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
i got my oil changed recently at 156k miles now its at 161... and funny thing is, around 158,900 miles, i put in an engine aditive called "Zmax" my dads used for years and we've seen insane gas mileage readings from it, and i just got back from a 15 hour trip from northern utah, avg speed of 75mph at 2800rpms, and i got avg 33mpg... which is interesting, because we did that and drove through the mountains really running the rpm's up close to 4k rpms... because before at 69/70mph, i got 33mpg (when i hadnt used zmax for a good year) and one time a few years ago my dad took a 11hr trip going 70mph non stop, and calculated 38mpg!!!
and funny thing now is, the oil although needs to be changed, runs better than it did when i got the oil changed... maybe its the zmax... eh?
MadDawg is offline   Reply With Quote
Old 04-09-2006, 08:25 PM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285280
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
mobil 1 and every 3000 filter as well, the car will last forever and a day
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-09-2006, 08:25 PM   #7 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397085
View RningOnFumes's Photo Gallery
the bottle says 15,ooo mile intervals, I do it at 10, ooo Does that help?
my current miles is 117, 000 roughly, at 125,000 will be my third time changing on this interval.
I'm using Mobil 1 synthetic and mobil 1 filter... and yes, the bottle clearly states 15k changes and full synthetic.
But like someone else said, you don't know how long you can go unless you do a test. I don't see anything wrong with you switching to 5k intervals, I'm not sure 10k because that's the owners perogative.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 04-11-2006, 08:26 AM   #8 (permalink)
View kevsbeamer's Photo Gallery
its fully up to the owner. It really does depend on how you drive,the wheather and what oil you use. You dont only just change it due to kilometres done. If you do alot of city driving, ie lots of starts and stops, you would "normally" change it every 5000kms, if its mostly highway driving aroudn 7000-8000kms. My parents usually change it like 10-15000kms at the stealerships when they go in for regular services. their cars run like shit in a few years but its not gona full screw your car up.
kevsbeamer is offline   Reply With Quote
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
First Oil Change Free? BobL94901 2nd Generation (2005+) 15 12-09-2006 09:12 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
2003 Camry LE V6 3.0 Oil Change SuperGT 5th & 6th Generation (2002-2006 & 2007-2011) 15 03-14-2006 08:07 AM
2001 Sienna went to get an oil change. Oil Plug loose, leak all the oil ...what now? 2k1Sienna 1st Generation (1998-2003) 3 11-29-2005 09:16 AM
