Alignment Camber - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2006, 11:00 PM   #1 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
Alignment Camber
Hey guys, I just got the results from my alignment
Camber Front left: -0.92
Camber Front right: -0.63
Camber Rear left: -1.28
Camber Rear right:-1.03
Do I need a Camber kit for this? and shouldnt things be at "0.00"
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 04-10-2006, 01:37 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
no to both questions.
I'm not sure what the gen4 specs are, but that's pretty much within the range I would think. I presume that those numbers are as close to stock as they were able to get you.
to give you an example, a stock gen3 alignment setup should be:
F Left Camber: -0.56°
F Right Camber: -0.56°
Front Caster: 1.19°
Side-to-side Caster variation: 0.75°
HaHa
Old 11-29-2006, 07:04 PM   #3 (permalink)
97 Camry
View Davee's Photo Gallery
Camber too high
My 97 4 cyl LE is burning tires on both front inside edges. I don't think it is toe in as no steering pull either way. I am thinking after 10 years the springs have lost strength & let the camber increase. Anyone seen this before? How about those coil spring lifter doolies to lift it back up? I never do alignments as tire replacements are cheap & new rubber for the winter is frequently required anyway. Is there a spec for length/height that I could easily check? Both sides are very close now to each other
Davee is offline   Reply With Quote
Old 11-29-2006, 07:29 PM   #4 (permalink)
The Greek....
GrkBallaG's Avatar
View GrkBallaG's Photo Gallery
THATS IT!!!!!!! your fine man, thats definatley within spec. If im correct the camber is -.56 plus or minus .75, so you can have up to -1.3 degrees of camber and still be within spec.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Steering and Alignment Problem on my '03 Highlander HiLander 1st Generation (2001–2007) 3 11-04-2009 10:38 PM
Rear wheel alignment problem on 2004 corolla S Fv53 Archived Corolla threads 1 02-19-2006 07:50 PM
Alignment (camber) question BillBrasky 2nd Generation (2005+) 4 02-16-2006 10:41 PM
Strut bar and alignment!!! need help Vampress Camry & Solara Lounge 17 06-28-2003 11:31 PM
Camber scam or paranoia? BenG Camry & Solara Lounge 8 04-26-2003 12:49 PM
