HVAC fan stopped working - possible causes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2006, 08:34 PM   #1 (permalink)
View RedRacer's Photo Gallery
4th Generation HVAC fan stopped working - possible causes?
The HVAC fan in my 1997 Lexus ES300 stopped working today I checked the fuses and everything is fine so I can only assume that the fan motor has died. Are there other parts I should check before ordering a new fan? Is this a common Camry/ES300 problem?
How many labor hours to change the fan?
Thanks
RedRacer is offline   Reply With Quote
Old 04-10-2006, 10:33 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
what's HVAC ?
Old 04-10-2006, 11:37 PM   #3 (permalink)
*INSERT WITTY TITLE HERE*
View BlueCam's Photo Gallery
Heating, Ventilation, & Air Conditioning
BlueCam is offline   Reply With Quote
Old 04-11-2006, 05:24 AM   #4 (permalink)
View karazy's Photo Gallery
I've never heard of the motor going. On the ealier models, there is a resister, at the blower, that tends to go bad. It usually leaves you with one speed though. It could also be the switch. I would test the fan, before ordering a new one. I'm sure it's not cheap.
karazy is offline   Reply With Quote
Old 04-11-2006, 04:13 PM   #5 (permalink)
Gameroom cash: $304255
You can check the fan with a test light or a DVM. You might have to remove a cover under the dash on the passenger side to get to the fan. Turn the engine on and turn the fan switch on full. Now crawl underneath with the test light. Ground the clamp end of the test light to something bare metal and backprobe the two wires leading to the connector on the fan. ONe of them will be the + side. If the test light lights up on either side it means power is reaching the fan and the fan motor is dead. If there is no power there, then work backwards to find the source of the problem.
If it is a bad fan motor, it's really not a hard thing to replace yourself. Once you have checked it out as I described, it will be obvious what has to be removed to remove and replace the fan. I haven't done one in about 10 years, but after removing a few small electrical components in the pick panel area to reach the fan motor, it was 3 nuts (or bolts) and one electrical connector to remove the fan motor. It's really not hard if you don't mind working on your back underneath the dash.
Mike
91 interior fan not working!!! ashley 1st & 2nd Generation (1983–1986 & 1987-1991) 14 06-26-2009 04:14 PM
'89T fan clutch engagement bosco659 Supra Forum 6 07-20-2005 05:55 PM
1993 v6 fan sensor farwest 3rd & 4th Generation (1992–1996 & 1997–2001) 0 06-18-2005 09:05 AM
Fan Noise - Climate Control Kobymonster 2nd Generation (2005+) 1 04-08-2005 03:41 PM
Passenger side window stopped working 92MR2 MR2 Forum 2 12-04-2003 02:36 PM
