Camry Internal Ignition Coil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2003, 07:49 AM   #1 (permalink)
View dubele's Photo Gallery
Hello. I'm a newbe. Here's a no brainer questions that I can't answer.
I am trying to replace the internal ignition coil in my Camry. There are 2 screws that hold it in. The problem is that they point towards the ground and are inaccessible. In the Haynes book, they are pointing towards the hood and are accessible. Is there a way to flip the coil housing or coil 180 degrees so I can get to the screws?
Thanks,
Doug
dubele is offline   Reply With Quote
Old 02-05-2003, 12:46 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
It would be a lot easier if you just took the whole distributor out. That is the best way of doing it.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
