Rear Lower Control Rods? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 03:51 PM   #1 (permalink)
Gameroom cash: $304255
Is anyone familiar with the rear suspension lower control rods on a generation 4 (1998)? I'm talking about the 2 rods in the rear that run laterally on each side in the rear. They are perpindicular to the wheel and tire combination. There are 2 on each side that are bolted together with long sleeves and bolts and have rubber bushings to cushion them. It's the rear one on each side, the one with the adjustment sleeve for the rear alignment, that I have a question about. I think Toyota calls this rear rod #2, but I'm not certain of that. With the rear raised off the ground I can grab hold of the each of the back rods of the set of 2 and rotate them till I have metal to metal contact within it's bracket. I can do this to the rear one on each side. The front one on each side is firm. There is no up and down or side to side movement at all, just rotational movement. That brings me to my questions.
1. Is this rotational movement considered normal?
2. Has anyone replaced the rubber bushings from these rods? If so, where did you get the bushings? The dealer doesn't carry them.
Thanks for any help here.
Mike
Old 04-11-2006, 10:13 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Mike I am pretty sure it is normal. WHen I was working at the dealer we did alignments all the time and all gen camrys were like that. I believe it is due to the fact that the alignment adjustments are made there.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 04-12-2006, 03:38 PM   #3 (permalink)
Thanks Chris.
Mike
2003 Tundra TRD, How to lower the rear suspenion to level the truck? Toynation 1st Generation (2000–2006) 2 03-29-2006 08:12 PM
86 lower control arms tdbudman 1st & 2nd Generation (1983–1986 & 1987-1991) 0 07-26-2004 09:31 PM
Lower control arm... Z0rn Supra Forum 1 04-24-2004 02:03 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
Whiteline Bushings speedemn Camry & Solara Lounge 18 04-01-2002 06:58 PM
