Intake Manifold Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 07:08 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Your probably gonna pity my dumbarse after reading this.
Well I was cleaning my throttle body today with some STP Throttle Body cleaner, and while I opened the butterfly plate by pressing down on the TB cable, the damn straw on the end flew off and into my manifold and fell into one of the pipes leading downwards...
My question: How hard is it to take the manifold off and how do you do it? I unfortunately had to drive my car afterwards to get to work...bad idea I know...but I couldn't risk getting fired...
Any help would be appreciated, thanks guys.
WhiteRabbit is offline   Reply With Quote
Old 04-11-2006, 08:52 PM   #2 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
I wouldn't worry about it. The engine would eat that thing with no problems. If it's still there, I would get long forceps and try to grab it. Can you see it, or are you guessing that it is still there.
I do remember a guy who had this happen, and it just dissappeared in the engine, with no ill effects.
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 04-11-2006, 08:53 PM   #3 (permalink)
View trickyazn's Photo Gallery
wow.. i cant help but lol.. someone answer this! im curious too.
trickyazn is offline   Reply With Quote
Old 04-11-2006, 09:15 PM   #4 (permalink)
TN's furry friend
i saw it in there, then tried to get it out, thats when the SOB fell in further...
i cant see it anymore now
Old 04-11-2006, 09:59 PM   #5 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Is there any way you could shine a light down there? If so, take a dowel (1/4") and put some gum or other sticky stuff on there, and try and prod around and stick it. GL.
BlueFusion6851 is offline   Reply With Quote
Old 04-11-2006, 10:14 PM   #6 (permalink)
View newbie212's Photo Gallery
Good Idea but I would just let it go like the other person said.. Sticking more stuff down there is taking a huge risk for something else to fall in which can lead to more problems..
newbie212 is offline   Reply With Quote
Old 04-12-2006, 07:59 AM   #7 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
good idea.. but how about that gray tape, that stuff is alot sticker then gum. tryto put it on a coat hanger.
project92camry is offline   Reply With Quote
Old 04-12-2006, 03:50 PM   #8 (permalink)
Gameroom cash: $304255
Don't feel bad. I had the same thing happen about 7 years ago. I was able to reach it with a long needle nose pliers. In your case, how about trying a shopvac with a long extension on it? Just a thought. Good luck.
Mike
Old 04-12-2006, 04:10 PM   #9 (permalink)
Gameroom cash: $147537
Remove the throttle body, you can probably fit your hand through. Long chop stick may work.
Old 04-12-2006, 04:38 PM   #10 (permalink)
TN's furry friend
it went down the one of the pipes connecting to the block, thats why i cant get to it anymore...
the vacuum sounds interesting if i can find one powerful enough, and if the straw hasnt melted sticking to the sides....
what i really need help on is how to take the manifold off, haynes isnt very descriptive and there is very limited room to work with behind there
Old 04-12-2006, 04:55 PM   #11 (permalink)
View marc780's Photo Gallery
That vacuum idea is a pretty good one. Maybe attach the vacuum hose to a piece of fuel line tubing using duct tape or what have you. And snake the tubing down the throttle body hole and go fishing until you can pull it up.
Old 04-12-2006, 04:59 PM   #12 (permalink)
After I lost my straw in the intake plenum, I found this item at a car show and have never been without one. They get brittle and break after a year or 2, so I buy a few of them to keep on hand when I see them. Check out this link:
http://www.bookofjoe.com/2005/07/holdit_never_lo.html
Mike
Old 04-12-2006, 05:11 PM   #13 (permalink)
There are 8 bolts and a support bar holding the manifold:
You may need to get under the car to get to those bolts.
Old 04-12-2006, 10:20 PM   #14 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dont worry about it, its too soft to hurt anything, my 89 has had a couple in there for about a year now if they are even still in there
Old 04-13-2006, 12:46 AM   #15 (permalink)
TN's furry friend
Mike
wow, those are looking pretty damn useful now
Diameter of Intake Manifold omar_shuja Archived Corolla threads 3 01-28-2006 06:54 AM
Intake manifold NIXmx Camry & Solara Lounge 6 01-17-2006 12:02 AM
How To take off the Intake Manifold?? leasaunce Camry & Solara Lounge 2 11-08-2005 06:33 AM
intake manifold turbo_GT MR2 Forum 0 04-07-2004 02:26 PM
