Another Brake Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 07:09 PM   #1 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Gen5 Another Brake Question
So today i was speeding to make a left hand turn, and while i was in the turn with an angle between 45~90 degrees. I pressed on the brakes, and the darn thing felt like it was going to fall apart on me. Like metal grinding on metal this is not the first time that when i make a turn and apply the brakes it feel like the whole thing is going to fall apart.
I have had the brakes inspected on numerous ocasions and nobody has said that they need replacing, but i can feel that the disks need resurfacing.
Does anybody know what could be going on?
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 04-11-2006, 07:27 PM   #2 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
if your a DIY kind of guy i would say replace the pads... when was the last time they were changed or are they stock ?
CamrySExxx is offline   Reply With Quote
Old 04-11-2006, 08:02 PM   #3 (permalink)
Dominican Republic
Dj-torn's Avatar
The car was bought used off of an auction, and i don't think the pads where ever replaced... so i would say that they are stock. ... Say i replace them.. what would be a good pad to buy?
Old 04-11-2006, 11:28 PM   #4 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
ABS? I can get the ABS to go off in my 04 very easily.
drunken_panda is offline   Reply With Quote
Old 04-12-2006, 12:08 AM   #5 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
yeah maybe it could've been ABS. It does feel weird whenever the ABS goes off whenever i do hard turns.
I've got Satisfied and Akebono brake pads. I forgot where i bought them though. =/
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 04-12-2006, 06:37 PM   #6 (permalink)
Dominican Republic
Dj-torn's Avatar
Conclusion 1. Let me see if im understanding. When i turn and brake rather hard the car switched from ABS to Non-ABS?
Or
Conclusion 2. Is it when i make the hard corners and brake that feeling i get is that of the ABS doing its job.?
So is it Conclusion 1 or Conclusion 2
Old 04-12-2006, 07:54 PM   #7 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Do you feel the vibration in the peddle as well?
Most likely is the ABS.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 04-12-2006, 08:50 PM   #8 (permalink)
Dominican Republic
Dj-torn's Avatar
Yes i do feel vibrations in the pedal aswell. It also feels like i'm not getting the regular slugish stopping put rather that i must apply more than normal. But b/c due to the odd feeling i don't and just get on & off the brake.
Old 04-12-2006, 11:49 PM   #9 (permalink)
VVT-i Owns's Avatar
Yep ABS. The kick back is normal. To take full advantage of it u should stay on the brake.
- Vince
Old 04-13-2006, 08:21 PM   #10 (permalink)
View fe519's Photo Gallery
goodness... you dont know what abs feels like?
fe519 is offline   Reply With Quote
Old 04-13-2006, 08:35 PM   #11 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
ABS feels weird the first time u notice it. Kinda scary even.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 04-14-2006, 09:54 AM   #12 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I don't have ABS so I haven't a clue what it feels like. However, I understand that you can disable it by unplugging it. The car then fail safes back to "regular" brakes. You could disable the ABS for a while and try the same cornering maneuver. If the vibration goes away (and returns when you plug the ABS system back in) then you know it is the ABS.
Kep
Old 04-14-2006, 10:11 AM   #13 (permalink)
Insert Custom User Title
BigPete's Avatar
View BigPete's Photo Gallery
Kep
yeah, you could disable it, but it is NOT recommended. The whole purpose of ABS is to keep the brakes from locking the wheels up and causing a slide. If you're getting a metal on metal sound, and you haven't changed your pads, and even you think that the rotors need resurfacing, then it sounds like you have some brake maintainance to do. Go get some OE pads from the dealer (don't know about the new gens, but on gen4, aftermarket pads squeal), and DIY, or pay someone to do it.
BigPete is offline   Reply With Quote
Old 04-14-2006, 11:06 AM   #14 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
i wouldn't recommend resurfacing... i did it and now my rotors are all warped and retarded... i'm still driving on them.. but going to replace them soon.
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 04-14-2006, 12:38 PM   #15 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
ABS testing - do it safely
If you want to experience the ABS feel, you can do it more safely then doing a hard cornering.
1. Make sure you on an open road area, with NO cars what so ever. Actually you don't even have to go that fast.
2. Drive in a straight open country road (no houses, intersections, kids, cars, etc, etc), if the road is slightly wet, its even better. Go about 60km or so, then slam on the brakes.. The ABS will vibrate (pulsate).
Again, do this in a safe open road. try this at your own risk.
If you are still not sure, why dont you take it to a dealer and get a mechanic to drive your car, most places wont charge you, but of course, ask first if there's going to be a charge.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Brake question dave_thomas Camry & Solara Lounge 12 08-10-2004 09:29 AM
Brake Rotor question techguy Camry & Solara Lounge 5 07-26-2004 11:12 PM
Question about Brake Bleeder valve.. GrantTPC Camry & Solara Lounge 7 09-14-2003 11:04 AM
Brake Question rpj1984 Hardcore Tech and Competition 3 09-03-2003 01:34 AM
Brake question. REN69 General Discussion 8 06-17-2003 10:07 PM
