changing auto to manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2006, 11:54 PM   #1 (permalink)
View The Black Camry's Photo Gallery
I saw this one 99 celica i like and i realy wanna get but theres a problem! its an auto!!! Now i was just wondering exactly how hard is it to convert a auto into a manual! And what things need to be done for this conversion?
The Black Camry is offline   Reply With Quote
Old 04-12-2006, 10:24 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
you are going to need a pretty much complete car to rob the manual stuff off of
Old 04-13-2006, 01:10 PM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
^ not really...
you just have to find these parts at a junkyard, make a hole in the firewall for the clutch master cylinder, install everything, and you are set.
tranny, mount, likely right side axle, clutch, flywheel, clutch pedal, brake pedal, master/slave cylinders & lines, shifter base, shifter cables, interior trim pieces if you want it right.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-13-2006, 09:37 PM   #4 (permalink)
Yeah thanks. but now that i think of it, it might be cheaper just to buy a manual!
Old 04-13-2006, 11:33 PM   #5 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
No actually I swapped my 97 5sfe to a manual with about $1200 and that is with a badass clutch and low milage tranny. I took a clutch pedal out of an 86 corolla since I couldnt find a camry one and made it fit. I got a master cylinder off some other car that mated up to the pedal. Basically I walked around the junkyard till I found a combo of stuff that worked. I made the clutch line out of autozone brake hardline, bought an ACT clutch, bought a tranny with 30,000 miles on it for $400, got a flywheel for $30, got tranny mount for $50 and the same axles were just reused. The slave cylinder was $20, the wiring was free, mostly cutting things out and the shifter was $50 I believe. If you look around the stuff is there and it is cheap. Plus the automatic has a bigger brake booster than the manuals so that is a bonus and you will know your car like the back of your hand! I had so much fun doing my swap it was great memories. Plus nothing like shifting into reverse and the dashboard light for the automatic glows R it cracks me up all the time. Go for it man its actually really easy in the end, its just nuts and bolts...
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 04-13-2006, 11:42 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
i did almost the same thing 97, i started with a 1990 celica shifter base, and did the same autozone hard clutch line.
Dave Zoni
Old 05-11-2006, 01:14 PM   #7 (permalink)
Aspiring to mod...
GrayGen4's Avatar
View GrayGen4's Photo Gallery
Would this work for an '01 as well? Basically I miss slapping gears when accelerating...
I'm under the assumption that I'd have to find a Gen4 tranny tho, right?
GrayGen4 is offline   Reply With Quote
Manual or Auto??? mayfly Camry & Solara Lounge 8 03-20-2006 12:16 PM
Faster 0-60 time = RSX Auto or tC Auto? cman2000 General Discussion 25 05-23-2005 02:40 PM
changing manual transmission fluid rodvc Yaris, Vitz and Echo Forum 2 03-29-2005 12:52 PM
Auto to Manual Swap imp pwr online MR2 Forum 0 03-29-2003 08:08 AM
