Originally Posted by t4x4_offroad
Thanks Mike. Yes, I am planning to bring it back to the dealer, since they only recently did the O2 change. My only concern is that they might end up saying that I need another expensive O2 sensor, which I don't think is the culprit this time, and I may have to argue my case here. Maybe the wiring between the sensor and the ECM is bad?
Has any one else had recurring O2 sensor issues?
If the code is the same, then the problem is probably the same.
I have a 6 cyl, and was getting o2 sensor codes. Ended up changing both sensors in the front to clear everything. Funny thing though, I think that I can trace my o2 sensor failure to my addition of a SRAI.
