Replacing rear valve cover gasket-HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2006, 06:13 PM   #1 (permalink)
View gbaoyn's Photo Gallery
3rd Generation Replacing rear valve cover gasket-HELP
Hi, I'm replacing the valve cover gaskets of my 3vz-fe.problem is the wires on the rear cover block the way to the firewall side bolts.I was trying to find how to remove it but failed.What I can see is there is a clip on Diaganose and another one on the timing belt cover,but they were not working and one bolt on the cover. Does anybody know if there is any trick to get to thpse bolts?
Thak you very much and by the way I'm planning to replace my timing belt and water pump after these gaskets.
gbaoyn is offline   Reply With Quote
Old 04-13-2006, 10:12 AM   #2 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
bump, plus...
please be a bit more discriptive,
also, the timing belt is a biatch, water pump isnt too bad, i recommend getting a gasket w/ the water pump (they make gaskets for them now) also get a new crank bolt, cause its a pain to get off, and you have to put alot of torque on it when putting it back in.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 04-19-2006, 11:20 PM   #3 (permalink)
unbolted that 2 bolts on the cover and unclip from the diagnose on the left side,but still can't not remove that wire. ThCan anybody advise how to remove the big wire behind spark plug wires to access the bolts of rear valve cover? I ank you.
Valve cover gasket replacement White Buffalo Pre-88 Toyota Pickup/Hilux 1 01-02-2006 06:37 PM
Valve cover gasket..few questions slbks5 89-95 Toyota Pickup/Hilux 3 11-06-2005 12:39 AM
97 Avalon Valve Cover Gasket hdt98 1st Generation (1995-1999) 4 11-08-2004 09:44 AM
Taking off the Valve Cover Piddy MR2 Forum 4 08-19-2004 11:53 AM
Valve Cover Gasket GoofyCamry Camry & Solara Lounge 6 02-20-2003 01:57 PM
