If it was working from the driver side switch but not its own switch initially I would sure suspect that the wiring inside the passenger side door got messed up. Since the driver switch worked and the passenger switch didn't I would lay odds on the problem being inside the passenger door. Before you buy a new motor, test the old one directly with a hot wire. If the motor works without a switch you can use a multi-guage to test your wiring and switches.
Don't focus only on one door or the other. I would start at the passenger door but if you don't find any problem check back to the driveside door. I currently have a bad wire in my driveside door. When I open the driverside door, neither the driver switch or the passenger switch will operate the passenger window. When the driver door is closed, both switches work. I am pretty confident that it is a wire broken where the driver door hinge is. I just need to take the time to fix it.
Later,
Kep
