Have Questions. Timing Belt Snapped on highway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2006, 02:52 PM   #1 (permalink)
View tousi's Photo Gallery
Today the timing belt in my 92 camry 4cy 5sfe just snapped while i was cruising around 60 mph. What is the worst case scenerio or the least? Bent Valves? Ect..?? Seeing if its worth fixing. lmk
tousi is offline   Reply With Quote
Old 04-14-2006, 02:57 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
It is a non interference engine so there is most likely no damage. Just pop on a new belt and you should be fine. But there is a chance that if you were at a higher rpm when it snapped that it could have caused some damage but i doubt it. Your engine should be fine.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-14-2006, 02:59 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
also when it snapped did you hear and ping or grind? or did it just stop running. If you herd no ping or anything like that you are fine.
Old 04-14-2006, 03:03 PM   #4 (permalink)
ping or grind as in metally like? iif yes, no i didnt hear anything like that,.
Old 04-14-2006, 03:06 PM   #5 (permalink)
View AutoBox's Photo Gallery
minimal...the 5sfe engine is non-interference, meaning if the timing belt breaks it will not cause any permanant damage, other than leaving you stranded.
If you jumped time and it wasn't that would be a different story. Get it towed to a reputable shop, a mechanic who is specialized with toyotas, or a toyota dealership.
AutoBox is offline   Reply With Quote
Timing belt replacement questions Vibroseis Camry & Solara Lounge 9 12-12-2008 08:12 AM
Changine Timing Belt..Found Oil behind Timing Covers A2brb Camry & Solara Lounge 11 11-14-2005 04:10 PM
Help with Timing Belt modifierLE General Discussion 1 09-16-2005 04:12 PM
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
timing belt - live update and questions BobES300 Camry & Solara Lounge 0 01-05-2005 02:11 PM
