Hi, guys, I'm failed to replace my timing belt today.
I got follwing problems:
1). REMOVING PS DRIVE BELT.
Manual says :loose the 2 bolts and remove the drive belt. But after I loosen the
bolts,enven took the 2 bolts and small metal plate off, the belt still stuck there. I took
it off after I remove the crank pulley.
2). REMOVE ENGINE RH MOUNTING BRACKET
There are 2 bolts on it.after I unbolted,the bracket can not be taken out. because those
2 bolts are so long ,especially right hand one. it has an angle, I can't take it out and
it also has something just ride above the timing belt. I didn't find the way to remove the
bracket.
3). INSTALL NO.1 TIMING BELT COVER
I was hurt so much on it. it took my more than 2 hour to install it.Finally, I put it on, but
I really don't know how. It 's so difficult to match the upper edge,it always stay outside
when I tried to match the left lower side bolt.
4).INSTALL PS DRIVE BELT
Like what I said on 1st question,I had to install it when I installed the crank pulley,but
I turned the crank pully counter clockwise 1/5 round(I think)when I put the belt on. Will
that be a problem with the timing? I haven't tried to start my car because I got a big
mistake
on my alternator adjust bolt. I broke it when I tryied to tighten the alternator
belt.The reason is I tightened the lock bolt first with a little bit unbalance
So,as you know, I failed to replace my timing belt, wish somebody give my some
answers about my questions, and also hope my story will give a little help to somebody
who is gonna try to do same thing.
Oh, by the way, anyone knows where I can get the alternator adjusting bolt(M8-1.25,
11.5 mm long). I checked Lowes, autozone and advance auto parts, but they don't have
it.
Thank you very much to read my long ugly writing and hope to get some from you guys.
