Third Gear Grind. . . Anyone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2006, 05:40 PM   #1 (permalink)
View TheToyotaKid's Photo Gallery
3rd Generation Third Gear Grind. . . Anyone?
Whats up guys, I have a 96 coupe that grinds third gear when I downshift from fourth, but doesnt grind from second to third.? Anyone got a clue?
Thanks guys
TheToyotaKid is offline   Reply With Quote
Old 04-16-2006, 09:55 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
dead synchro most likely, bearing gone not so likeley.
maybe less of that machine gun hammer shifting =)
terrastrife is offline   Reply With Quote
Old 04-17-2006, 12:20 AM   #3 (permalink)
View marc780's Photo Gallery
Yeah, synchros about the only cause of this. Unless youre planning a trans rebuild soon, id just take it easy downshifting. Maybe drive so as to match the revs useing the old double clutching technique to take it easy on this transmission.
Also maybe try changing your gear oil and dump in a can of STP oil treatment too. And also, maybe your clutch is wearing low, this could affect it too.
Old 04-17-2006, 09:03 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307175
First, learn how to double clutch and rev-match on your downshifts....
Also, replace your tranny fluid. Add a quart of GM Syncromesh fluid to the mix and most of the grinding should go away.
-Charlie
Cannot shift into gear! SLC Punk Celica Forum 3 04-02-2009 06:57 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 01:08 PM
tranny gear grind MR2Enthuze MR2 Forum 5 04-02-2005 10:12 AM
Gear ratios for 2005 Tacoma 6 speed? lbmii 2nd Generation (2005+) 1 02-27-2005 01:17 AM
