Window Problems...Need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 09:02 AM   #1 (permalink)
View 99camryLE's Photo Gallery
4th Generation Window Problems...Need help
Alright, my driver's side window is acting up. When I try to close the widow, it goes about half way and stops. When I look outside, it looks like that black seal around the window is getting stuck in the window, which is making it slower. Is this happened to anyone before? The window closes, after manually pulling it up in conjunction with lifting the switch. when the window is closed, the balck seal is squezzed between the window and door. sometimes, it won't even come out of the door. It isn't the fuse, because the other wondows work fine. My dad says it's the motor which needs to be replaced, and I know this is a common problem among 4th gen camry's, but i still think that it's something else. Does anone know what it could be???
Its not what u drive, its how u drive it!
99camryLE is offline   Reply With Quote
Inside window seal gap cactusone 2nd Generation (2005+) 8 03-21-2006 08:27 AM
Gen 2 manual window problems 89SV21 1st & 2nd Generation (1983–1986 & 1987-1991) 0 02-03-2005 02:58 AM
For All You WINDOW PROBLEM guys. stizick37 Camry & Solara Lounge 6 06-07-2004 11:07 AM
Gen2 window problems.....already searched.. storydude 1st & 2nd Generation (1983–1986 & 1987-1991) 8 08-28-2003 01:49 PM
window problems need help jiggaboo Camry & Solara Lounge 5 08-26-2003 03:38 PM
