Emissions fail - high HC
94 V6 XLE failed emissions with high HC for the second time. First time it failed with high NOx as well, but new plugs seem to have cured that. Also replaced air filter and PCV.
Comparing with my 2003 emissions test, HC is up from 0.01 to 1.05 ppm and CO is up from 0.01 to 4 ppm.
From forum searches and other research, sounds like one or more of:
- bad cat
- vacuum leak
- leaky injectors
- faulty O2 sensor(s)
- EGR system problem
- faulty termostat
Are any of these more likely than the others? Any other likely culprits?
I'm also wondering why it hasn't thrown a code. Is it possible to have a faulty O2 sensor but no CEL?
--- Procrastination ---
"Hard work pays off over time, but laziness always pays off now."
