I have read all the other threads, just a quick question. I have an 03 Camry with auto trans. Do I have a 10 mm hex head for drain plug. For some reason I thought the new Haynes manual said 14mm? Does anyone know which one it is? I misplaced my Hayned manual.
Is my trans and diff the same unit using the same fluid? I belive it is. If so I just drain from the plug and refill, no other plug for diff, correct? Then I am going to disconnect the passenger side hose to radiator to complete the flush. I am glad I read alot. You can't use Mobile 1 synthetic in a trans that requires Type IV Fluid. I almost screwed up my beauty
