camry acceleration problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 08:48 PM   #1 (permalink)
View userid's Photo Gallery
Whenever starting from a cold start, my gas pedal would get stuck after a stop. It'd stuck for a few second, and if i continue pressing, it would eventually work. After the engine warmed up, the problem goes away. Any ideas?
userid is offline   Reply With Quote
Old 04-17-2006, 09:11 PM   #2 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
what year engine ect. ctc.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-17-2006, 09:23 PM   #3 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Did you try having someone press on the gas while you take a look at the throttle cable and all that?
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 04-17-2006, 09:35 PM   #4 (permalink)
View marc780's Photo Gallery
Try cleaning the throttle body. The butterfly valve might be stuck from being crudded up. Its easy to do, remove the air cleaner tubing. Work the accelerator linkage to see the butterfly open and close. It will be dirty and also the contact area it touches inside the throttle body wall will be dirty too. Clean these deposits off with carb cleaner and a rag and old toothbrush. Maybethis will fix the problem.
Old 04-17-2006, 10:07 PM   #5 (permalink)
That sounds fairly complicated, as i have no clue what the butterfly valve or throttle cable look like. I guess off the the shop it goes, it's due for the 90k services anyway, any clue on how much that will cost at the dealer?
thanks for replying, it's a 99 camry, 4 cyl.
Old 04-18-2006, 01:32 PM   #6 (permalink)
However much they charge for this is too much if it is more than $3.99. Because thats all you need for a can of carb cleaner.
Its not hard, you undo the big hose clamps on each end of the air filter tube (big ol plastic tube between housing and throttle body). Then wiggle and pull it out. The butterfly you see inside the TBI is the thing you need to clean. Soak the area with carb cleaner and wipe with rag.
Gently push the butterfly partway open with a screwdriver or even a pencil, and clean the area the butteryfly touches inside the TBI. Wipe itc lean with rag, make sure you left no tools in TBI lol. Reassemble the aircleaner hose. Thats it.
It would run rought for a minute while the engine burns the carb cleaner, this is normal. And then it will run more smoothly after that.
Old 04-18-2006, 01:45 PM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
yeah its really as simple, but if you are really unfamiliar and dont have some manual or a friend to ask and if you're very uncomfortable, then just wait for the service and see what they say. If they plan on charging you more than 15 bucks for fixing the problem...try doing it yourself first.
nodrogkam is offline   Reply With Quote
Old 04-18-2006, 05:34 PM   #8 (permalink)
Gameroom cash: $304255
It really is an easy DIY task. Do a search on this forum for "throttle body cleaning". There should be some good posts on it, including some with step by step instructions and some with pictures.
Mike
Old 04-18-2006, 05:35 PM   #9 (permalink)
Moving Forward
View Cyorke's Photo Gallery
clean the throttle body. remove the air intake hose and spray with throttle body cleaner.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 05-20-2006, 11:56 PM   #10 (permalink)
The sleeper has awaken
spdlva2nv4eva's Avatar
View spdlva2nv4eva's Photo Gallery
i clean the throttle body and its still feelin a little heavy. the accelration problem is a lil issue still and im gettin a weird feeling that my odometer is reading incorrectly for some reason.
spdlva2nv4eva is offline   Reply With Quote
98 camry le v6: Trunk Lid light/ Back up lights not working, Problem and solution ihqazi 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-26-2009 01:01 AM
94' Camry Coupe V6 LE Engine Shut Off Problem farooqm78 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-20-2005 01:12 PM
'90 Camry DX - dash light problem CHaynes112 1st & 2nd Generation (1983–1986 & 1987-1991) 2 01-24-2005 05:31 PM
2003 Camry problem newcamryowner 5th & 6th Generation (2002-2006 & 2007-2011) 5 07-06-2003 02:04 AM
