VZ AFM's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 07:53 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
VZ AFM's
Anyone ever compared the size of the 2VZFE and 3VZFE air flow meters??
I wanted to know the size difference between the two.
Im thinking that if they run basiclly the same (since there both VZ series engines) it could be used as a good upgrade for the 2VZFE.
This also begs the question of wether the 2VZ injectors would be too small for the extra airflow (if infact it is bigger). So perhaps using 3VZ or larger injectors would be a good idea, and combined with some fuel managment, would make some nice power/torque.
Just a thought.
Throw some ideas
EDIT:
Just took a look at this site: http://toysport.com/webpages/Techinf.../injectors.htm
According to that, the only difference between the two is the color (red, brown) so..would simply strapping on the 3VZ AFM onto the 2VZ work!??
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-19-2006, 08:12 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
with your safc retuned yes =)
connectors are the same, they both use the inverse voltage output but there may be difference which youll need to correct.
or so in theory =)
the 7M engines also use the same deallie.
terrastrife is offline   Reply With Quote
Old 04-19-2006, 08:22 AM   #3 (permalink)
VeeZed
so 7M and 3VZ would be about the same size?
Old 04-19-2006, 10:36 AM   #4 (permalink)
yes, i have a 7M afm/pod adaptor lol.
Old 04-19-2006, 07:17 PM   #5 (permalink)
VeeZed
Mmm..so anyone else have any ideas/input?
Old 04-19-2006, 07:32 PM   #6 (permalink)
engineer in training
Gameroom cash: $145055
All I know is we 3vz people have the largest AFM Denso makes, and it has an odd trait, the voltage goes from 5v-0v instead of 0v-5v as it is opened.
Old 04-19-2006, 10:23 PM   #7 (permalink)
aha you lurker! hows the car?
VZ block EGR for dummies Toysrme Camry & Solara Lounge 0 11-03-2004 08:35 AM
VZ Block Parts Interchange jackfrost1031 Camry & Solara Lounge 1 07-03-2004 11:45 AM
