well this is for the Left had drive version but it should be the same.
The plastic surrounding the radio jsut clips in. It looks like a U. At the top you can put a small screwdriver between it and the dash pad and pry out slightly. IT should pop out fairly easy. Once you get that out there should be four screws that hold the entire radio and pocket assembly in place. Remove those four screws and everything pulls out. Remove the screws that hold the radio to the carriage and you are ready to install your new HU. Installation is reverse.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
