Need help with idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 01:51 PM   #1 (permalink)
View natedizzy's Photo Gallery
3rd Generation Need help with idle problem
I was charging the A/C on my wife's 93 camry 4 cylinder and the engine stalled out. When I started it back up it does not want to stay running. The idle jumps between about 300 and 800 rpm unless I hold the gas down to about 1000 rpm. When on the highway it seems alot more jumpy and starts surging every once in a while. Nothing else has been touched and it's probably a coincidence I was working on the A/C when this happened. Any help would be greatly appreciated.
natedizzy is offline   Reply With Quote
Old 04-19-2006, 02:47 PM   #2 (permalink)
View mtnbkr's Photo Gallery
Did you overcharge it? My Paseo did the same thing when overcharged by a bit. Release some coolant and it'll settle down.
Chris
mtnbkr is offline   Reply With Quote
Old 04-19-2006, 03:32 PM   #3 (permalink)
I thought that might be an issue. I checked it with a gauge and it looked fine. I went ahead and let almost all of the refrigerant out and it is still doing the same thing. I also checked the distributor cap and rotor and it looks fine as well.
Old 04-19-2006, 06:27 PM   #4 (permalink)
View Brujo's Photo Gallery
Something similar happened to me but it turned out to be dirty/loose connection to my battery. Don't know if this will help you any.
Got CAI? Check out my custom CAI! Click here
Brujo is offline   Reply With Quote
Old 04-20-2006, 12:38 AM   #5 (permalink)
View marc780's Photo Gallery
Clean the butterfly in the throttle body. If that doesnt fix it remove the TBI (3 bolts on the 4 cyl) and unbolt the iac from the bottom and clean it with carb cleaner. Usually works
Cold start idle problem 4age bubbawing Archived Corolla threads 2 12-15-2005 05:50 AM
IdLE PROBLEM ZIXXER 1st Generation (1995.5–2004) 2 12-07-2005 06:47 AM
how do correct idle problem 1quickmr2 MR2 Forum 2 04-22-2005 07:49 AM
88 Camry - Idle problem after a hard stint JetspeedCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-24-2004 11:15 AM
Idle problem. Need Help... oreo Archived Corolla threads 5 12-13-2003 05:13 PM
