Apexi ITC - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 03:02 PM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Apexi ITC
Well Im excited, I bought an Apexi ITC which should be able to help me retard timing under boost. The only problem is hooking it up. All the manuals are in Japanese. I figured out ground and positive and all dip switches are up, vehicle type is 0 but I just need to splice in the crank angle sensor and cam angle sensor. Anyone have any input?
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 04-19-2006, 04:36 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need a pinout diagram for the ecu.
Look in the sticky threads in the Camry forum for manuals.
"Skoolin' the unlearned!"
Old 04-19-2006, 08:53 PM   #3 (permalink)
97camryman's Avatar
Good call man I hit up the gen 4 wiring diagrams and printed the whole thing out. Shows the Cam angle and Crank angle sensors grounded to a common point with their positive leads coming back into the ECU which is where I will intercept them. I like that it does not retard based solely on boost, I can pull timing across the whole rpm range and make a rough curve. This will be very nice to have, hopefully I can push a safe 7 psi now with 93 octane fuel, SAFC2, and intercooler along with the usual rest. I see that a some people take out 2 degrees base timing and leave it at that. I have more flexibility to retard less down low, then pull the most timing at peak torque and then feather out the retard again above that. Any other suggestions?
apexi super itc on 2nd gen 3s-ge `d3x Hardcore Tech and Competition 5 07-13-2005 07:09 PM
