Huge oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 04:25 PM   #1 (permalink)
View Gavin96V6LE's Photo Gallery
Huge oil leak
Valve seals are totally done oil leaking very quickly..Worth it to get it fixed anyone has the valve seals replaced how much with labour? and is the head gasket next? would like to hear your opinion its V6 and only the back bank seals are leaking..is this the end for the camry.. would like to hear your opinion or suggestions.
Gavin96V6LE is offline   Reply With Quote
Old 04-19-2006, 04:30 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Certainly not the end...
The best thing to do here IMO is rip off the heads, get the valves done/maybe reground cams to spec, shims etc. Renew headgasket (might aswell) and replace timing belt (while youve go the cams and that out). If you wanna pull the motor to do it, change water pump and other hard to get this while its out!
Unless your talking about valve COVER seals...in which case...i don't see what the fuss is all about...just replace em.....
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-19-2006, 04:51 PM   #3 (permalink)
possible just valve cover
but the why would the cover seals leak soo much oil? arent the cams inside that?
Old 04-19-2006, 05:57 PM   #4 (permalink)
View hooRAH's Photo Gallery
Valve seals won't leak to the outside of the car. Replace the valve cover gaskets.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 04-19-2006, 06:37 PM   #5 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
If your vavle seals are gone, then the only place you would be leaking oil is into your cylinder heads causing you to burn it leaving blue smoke wherever you go. Its not something you can just pop the hood and see.
As hooRAH said, replace the vavle cover gaskets, shouldnt cost you much. Just about everyone has had a leaky valve cover gasket at some stage.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 04-19-2006, 08:12 PM   #6 (permalink)
Thanks
very much i am hopen its just the vavle cover gasket and yet i hope my mechanic doesnt friggen say its gunna tak 5 hours labour ( 5x 60$) plus gasket. well he is a good guy and i respect him just friggen labour man...Is valve gasket a sign of other things to come or what?
Old 04-19-2006, 08:25 PM   #7 (permalink)
View Gary_602Z's Photo Gallery
It is just something that happens. Has no bearing on wetheryou will have other problems or not.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 04-19-2006, 11:07 PM   #8 (permalink)
car seems kinda boggy
Like not performing to well I know its the valve gasket seal. but would that be affecting peformance as well? low oil pressure?
Old 04-20-2006, 02:57 PM   #9 (permalink)
The only thing it could possibly affect is vacuum in the crankcase, like leaving the oil cap off. It will not change oil pressure.
Old 06-04-2006, 04:02 PM   #10 (permalink)
View marc780's Photo Gallery
Gavin i would do a compression check on this engine. And i'd try to save myself some work by checking the outside cylinders first (the easy ones). And if they had good results only then check compression in the back 3! But if the compression readings are low, hope not, but - if they are, then you have your answer as to why performance is not good.
V6 Compression readings, desired, range 145 PSI (minimum) - 218 PSI
variation between cylinders, 15 PSI max
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
2001 Sienna went to get an oil change. Oil Plug loose, leak all the oil ...what now? 2k1Sienna 1st Generation (1998-2003) 3 11-29-2005 09:16 AM
90 4Runner with oil leak RangerZ 4Runner Lounge 2 10-05-2005 05:07 PM
Oil leak with a strange story behind it... ivj Camry & Solara Lounge 11 03-13-2005 12:05 PM
help! oil leak 97Camry/blue Camry & Solara Lounge 7 07-26-2004 08:53 PM
