Brakes, did I miss something? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 05:29 PM   #1 (permalink)
View Grayguy's Photo Gallery
Ok, lately my brakes have been leaving something to be disired. When i first got the car from my mom 2 summers ago, I could stop well, and had the ability to lock the brakes up. Now, they are kinda crappy. I noticed a few squeks, so i pulled the calipers off and replaced teh front pads even though they didnt' need it (old pads were about 1/2 life) Then I just pulled the rear drums and the shoes probably have about 3-4 mm left on them.
So, what did I miss. Why aren't my brakes stop like I think they should?
Grayguy is offline   Reply With Quote
Old 04-19-2006, 05:55 PM   #2 (permalink)
View hooRAH's Photo Gallery
Because you're having difficulty generate brake line pressure.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 04-19-2006, 06:22 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
^ in short- bleed your brakes, and check your master cylinder
HaHa
Old 04-19-2006, 06:27 PM   #4 (permalink)
how does one "check" their master cylinder. I already checked fluid level...it's good.
Old 04-20-2006, 12:41 AM   #5 (permalink)
View marc780's Photo Gallery
Bleeding brakes means removing the air from the system. Fluid is incompressible, air is compressible when mixed with brake fluid. So search a post on how to bleed brakes and bleed them. If you bleed them and still does not brake well, then you probably need to replace the master cylinder (and bleed that too).
Also your rotors and drums should be smooth, if they are rough it will definitely interefere with good braking (the linings have less metal to grab if surface is rough).
Old 04-20-2006, 02:49 AM   #6 (permalink)
View Gavin96V6LE's Photo Gallery
you would be surprised
how much shocks affect breaking..but master cylinder does have its part
Gavin96V6LE is offline   Reply With Quote
Old 04-20-2006, 09:34 AM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
your brake pads and discs weren't glazed or damaged were they? Having some...well A LOT of fun in my dad's corolla which doesnt have ABS totally caused the brakes to be crispy, and in turn it was harder to stop and it was almost impossible to lock up the brakes unless it was soaking wet outside.
nodrogkam is offline   Reply With Quote
Old 04-20-2006, 06:36 PM   #8 (permalink)
I am well aware of how to bleed brakes, thanks. He said "check the master cylinder" and I'm still not sure what he means. All my springs and struts are shot to crap. I ordered new stuff a week ago and it's still not here
Old 04-20-2006, 09:30 PM   #9 (permalink)
View Gary_602Z's Photo Gallery
Only true when putting new pads/shoes on grooved rotors/drums. Once they wear in your stopping power is almost good as new as long as everything else is working right
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 04-20-2006, 11:57 PM   #10 (permalink)
Cressida nut
Gameroom cash: $249445
View kamesama980's Photo Gallery
well the shocks/struts will definitely play a major part, as will bleeding the air. by checking the master cylinder he probalby means make sure its sealing well, that the piston or cylinder doesnt have gouges somehow.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
92 Previa Cold Engine Miss leanscribe Previa Forum 2 04-23-2005 04:26 PM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 04:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
New brakes? CrawlingEye Camry & Solara Lounge 20 03-22-2004 12:14 AM
