I put mine where the ... dangit i don't know what it's called. ... trailing arm? Well, it's a bar that connects to the axle carrier on the rear, and it runs toward the front of the car. Where it meets the chassis is where I usually lift mine. You can grab the joint itself or the bracket it goes to. Unfortunately I don't have any pictures to show you exactly where...
There's always the option of putting it down on the seam, but I hate to do that, i've seen too many seams bend, and it aint' pretty.
To get the car in the air there should be a metal bar along where the axle would be ... i got no clue what it is but it has a little bump in the middle .. thats what I lifted mine by when I was placing the jack stands on either side.
Good luck!
