Valve Cover Gasket: OEM Vs. Aftermarket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 12:09 PM   #1 (permalink)
View simplyxtrippin's Photo Gallery
3rd Generation Valve Cover Gasket: OEM Vs. Aftermarket
i have a 92 cam v6 xle. valve cover gasket is leaking. i fount this gasket set from ebay. its company is called Felpro.
http://cgi.ebay.com/ebaymotors/Valve...spagenameZWD1V .
has anybody have any experience with this brand? or do u guys just recommend the OEM gasket? how much would the OEM cost. im kinda low in cash and the price of the Felpro gasket wouldn't hurt that much. comment and recommendation would be greatly appreciated. thank you.
simplyxtrippin is offline   Reply With Quote
Old 04-20-2006, 12:11 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
felpro makes the best gaskets.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-20-2006, 12:21 PM   #3 (permalink)
awesome. so i guess i should order these soon. thank you.
another thing, how hard is it to remove the rear valve cover? i know i have to take out the intake and all. in a scale of 1 to 10, 1 is changing oil and 10 is an engine rebuilt, what would you guys rate this?
Old 04-20-2006, 12:23 PM   #4 (permalink)
do those look like felpro gaskets? i don't know how they look like and i dont see a label. i don't want to get ripped off with a cheap gasket. thank you.
Old 04-20-2006, 12:46 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
actually that looks like a cheapo gasket set, but it lists the felpro part # because felpro part numbers are a sort of standard.
Dave Zoni
Old 04-20-2006, 02:59 PM   #6 (permalink)
i guess ill just shop around the auto parts store and see if they have felpro.
Old 04-20-2006, 05:26 PM   #7 (permalink)
View gbaoyn's Photo Gallery
I purchased from 1sttoyotaparts.com at $15.50/pc,total $31.00 for my 92 le v6.
gbaoyn is offline   Reply With Quote
Old 05-08-2006, 08:05 AM   #8 (permalink)
do they seem to be some pretty good gaskets?
Old 05-08-2006, 02:10 PM   #9 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
just go to advance auto parts,
tada!!!!
http://www.partsamerica.com/ProductD...pe=107&ptset=A
thats where i got mine, have yet to put them on tho.
you even get the plug tube grommets ( a must if replacing valve cover gasket)
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 05-09-2006, 02:37 PM   #10 (permalink)
View marc780's Photo Gallery
I been using felpro all my life. They're good, as good as your installation. If you clean the gasket surface properly and use sealer according to instructions, they will generally work and not leak. They are what the auto parts gives you so usually you dont get to choose the brand, but they are fine. Unless you want to get Toyota parts $$$.
Replacing Valve Cover Gaskets mnrolla T-100 1 04-23-2006 02:06 AM
valve cover gasket question Tercel Lady Tercel, Paseo, Starlet, and Sera Forum 13 03-13-2006 10:14 AM
Removing Gen 2 Valve cover? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-20-2005 10:53 PM
Valve Cover Estimate ArmyofOne Camry & Solara Lounge 5 10-02-2004 10:15 PM
OEM or Aftermarket? Corbett Archived Corolla threads 4 08-27-2002 01:05 PM
