nedd help w/ camry losing power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 01:03 PM   #1 (permalink)
View racemom44's Photo Gallery
i have an 88 camry - and it is getting terrible gas mileage lately and when the car in under a load - like going up a hill - it barely runs and loses power - the check engine light also comes on. I have a vacumm line on top of the value cover that keeps blowing off
But i also noticed that when i get home the engine and exhaust are really hot to the touch and about 1 1/2 later its still hot - any suggestions or advice - we did a tune up on it and changed the fuel filter - i was thinking it could be the cadillac convertor maybe. Any thoughts or suggestions will be greatly appreciated
racemom44 is offline   Reply With Quote
Old 04-20-2006, 03:44 PM   #2 (permalink)
Gameroom cash: $304355
"the check engine light also comes on."
Start by checking for stored codes in the computer. All you need on these OBD1 systems is a piece of wire or a paper clip. Look up the procedure in any manual or try Autozone.com on line for the proecedure.
Mike
Old 04-21-2006, 12:01 AM   #3 (permalink)
View marc780's Photo Gallery
Racemom you dont say how many miles on this engine, but if its over 100,000 i would start the diagnosis with a compression check. Minimum psi is 142. If its lower than this maybe you need a valve job or rings or time for another car...
If the compression check shows high enough then maybe you just need a tuneup wtih new plugs and plug wires, distribuotr cap and rotor, and a new fuel filter and air filter. And try some 91 octane gas
Old 04-21-2006, 01:09 AM   #4 (permalink)
Cressida nut
Gameroom cash: $249445
View kamesama980's Photo Gallery
first guess would be vacuum leaks. especially since oyu say the hose is blowing off...loss of power, running hot (from lean combustion) CEL will come on if its lean enough long enough or pinging...you really need to pull the codes. short t1(te1?) and e1 in the diagnostics plug in the engine bay and count the flashses of the CEL inside with the key on/engine off.
the hose is probably the PCV hose, and when it blows off, you get a vacuum leak to the manifold giving you the trouble. you can probably get a new hose at an auto parts store or toyota dealer...or pay $2 and get some hose from a hardware store and plug it in there.
LOL @ cadillac converter.....catalytic converter is how its spelled unless youre putting GM hardware in your camry.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
2000 Camry Remote Power Trunk pretender 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-09-2005 07:50 PM
92 camry power problem-please help ashok patel 3rd & 4th Generation (1992–1996 & 1997–2001) 11 01-19-2005 10:45 PM
How Would I Be Able To Get The Most Power Out Of My Amp? Vato Loco Audio, Video, and Security - Tech 6 10-26-2004 02:22 PM
Making some cool power (caution! For reference use only ) AngryAE101 Archived Corolla threads 5 11-03-2003 10:03 PM
