Rotor Size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 01:28 PM   #1 (permalink)
View yota's Photo Gallery
4th Generation Rotor Size
97-00 Camry. What is the diameter of the stock 4cyl front rotor? And what is the size of the 6cyl front and rear rotor?
99 camry
i/gc's with tokicos/04 camry wheels with azenis/trd rsb/trd lip
94 integra ls (totaled)
i/im/h/c/e/fpr/no cat
www.honda-tech.com
yota is offline   Reply With Quote
Old 04-20-2006, 02:00 PM   #2 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
http://www.coximport.com/brembomake/TOYOTA
this link should probably help you out..
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 04-20-2006, 03:14 PM   #3 (permalink)
Thanks for the link. So the 4 cyl rotors are 255mm which equates to roughly 10 inches and the 6cyl rotors are 275mm which makes those alittle less than 11 inches.
I recently ordered some new rotors for my 4 cyl camry. Looks like the guy sent me 11 inch rotors instead of 10 inchers. Does anyone know whether these are going to fit or not??? Do i need a different caliper to make them fit?
99 camry
www.honda-tech.com
Old 04-20-2006, 03:39 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You should stick with 10 rotor.
If you want the 11 inch ones, you will need torque plate (for the V6 models, or 2002 and on camrys) and the larger caliper, with different pads (IIRC 706 or 703).
Then you may need to get wheels larger than 15 inches for the clearance
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-20-2006, 06:24 PM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
unsure about the calipers and what not, but the v6 has 15 inch wheels so that should be okay.
nodrogkam is offline   Reply With Quote
Old 04-20-2006, 06:59 PM   #6 (permalink)
slowamatic noob
yea just stick to the stock ones cuz it seems the guy sent you the v6 size rotors... and yea 255mm is about 10 inches..
