Diagnostic terminals goopy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2006, 09:11 AM   #1 (permalink)
View wanman75's Photo Gallery
3rd Generation Diagnostic terminals goopy
Hey all....
I went to pull some codes off the diagnostic box and when I opened the cover, the terminals are covered in some kind of goop or grease. What is this stuff?
Oh yeah... this is on a 1MZ, in case it matters....
--- Procrastination ---
"Hard work pays off over time, but laziness always pays off now."
wanman75 is offline   Reply With Quote
Old 04-21-2006, 09:41 AM   #2 (permalink)
Never mind... must be dielectric grease.
Old 04-21-2006, 10:48 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
^you got it.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-21-2006, 12:40 PM   #4 (permalink)
Ok... so what's the safest way to remove it? I tried to use a paperclip to connect TE1 to E1, but I'm not getting a connection (my CEL doesn't blink).
I suppose I could try using a small screwdriver to wipe/scrape the contacts, but there has to be a better/easier way.
Would electrical contact cleaner work?
Old 04-21-2006, 01:38 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
If you can actually feel it making contact, I'd say look elsewhere. I've used LOTS of worse conductors and never had a problem with the grease blocking the flow.
Old 04-21-2006, 01:42 PM   #6 (permalink)
I'm a Mac
zoni's Avatar
the goop isnt bothering it... it must be something else... that goop is OK with connections.
Dave Zoni
Old 04-21-2006, 02:43 PM   #7 (permalink)
Hmmm... when there aren't any stored codes and TE1 and E1 are jumped, the CEL should just blink continuously, right?
Old 04-22-2006, 01:22 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need a scanner to pull the codes on a 1MZ-FE.
Jumping TE1 and E1, does not work.
"Skoolin' the unlearned!"
Old 04-22-2006, 05:00 AM   #9 (permalink)
Well, that explains it. Thanks. I actually did drop by the Autozone and plugged in. No codes. Now to figure out why I failed emissions without codes...
Old 04-22-2006, 03:42 PM   #10 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
how hot/warm was your engine when you took the test?
even if you had warmed up your engine good before hand, if you had to wait for them to put the car on the rollers, then it can make a big difference- tell them to run your car ON the rollers for a couple of minutes before plugging you in for the test
as well, excess carbon in your intake/engine/exhaust can cause extra emissions without throwing a CEL- you will really only get a CEL if your o2 sensors are gone or are getting extreme readings such as a clogged cat
HaHa
Old 04-22-2006, 05:21 PM   #11 (permalink)
It was warmed up. Right off the highway, engine coolant temp 180. Went right onto the dyno. High HC and High CO = Fuel Mix Rich. So.....
- vacuum leak (can't hear one)
- leaky injector(s) (I want to leave this until last)
- ECU fried (not likely, since it does seem to be operating normally otherwise)
- bad cat (not sure how to test it)
- misbehaving O2 sensor(s) (need to stick them on a VOM)
Car has new plugs (Denso Iridium), new air filter, new PCV. I cleaned the MAF sensor and throttle body, gave it 2 seafoam treatments (which also showed me a small leak in the exhaust manifold!), ran a tank of Techron Fuel SYSTEM cleaner.
I was going to just R&R all the O2 sensors since I've read the service life is 60,000-100,000 miles (my Cam has 220,000), unless there's something else I should be considering.
Any other thoughts?
Old 04-23-2006, 01:21 AM   #12 (permalink)
I'm a Mac
zoni's Avatar
o2 sensors likely
pull the EFI fuse to release the codes, then put it back in... if the engine light comes back on., then you know something is actually wrong.
Dave Zoni
Old 04-23-2006, 01:16 PM   #13 (permalink)
Thanks Zoni... but I forgot to mention that the CEL didn't come on at any time. The only reason I put the scanner on was to see if there were any stored codes that didn't light the CEL.
Front (left bank) O2 is dead easy to get to, and I suppose the one near the cat will be fairly straightforward. What's the easiest way to get at the right bank sensor? From up top or from below? Any gotchas?
Old 04-23-2006, 01:25 PM   #14 (permalink)
I'm a Mac
zoni's Avatar
the sub o2 sensor isnt too important... just worry about the main 2.
from the bottom.
Dave Zoni
Help with Toyota diagnostic codes jeffoxen Camry & Solara Lounge 2 06-02-2006 11:35 AM
Checked the IAC valve's operation by jumping terminals 97&02camryleI4 Camry & Solara Lounge 20 03-25-2005 05:34 PM
Adjusting Idle and Diagnostic Wire chicagoguy Celica Forum 4 03-13-2005 12:43 AM
Diagnostic Test Connector REDSOXTICKET Camry & Solara Lounge 3 06-07-2004 11:28 AM
