Squeaking rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 01:14 PM   #1 (permalink)
View Meisner's Photo Gallery
3rd Generation Squeaking rear
I have a '96 4-cyl that has a horrible squeak coming from the rear as I encounter little bumps in the road.
I have modified the rear as follows:
- Whiteline 18mm sway bar
- Toyota rubber sway bar bushings (also tried the ones that came with the Whiteline bar)
- Stock/original end links
- Tokico struts
- Eibach springs
- Stock/original strut mounts
- Stock/original spring mounts
The springs & struts are about 30,000 miles old. I can swap the bushings and the noise doesn't change at all. I even tried greasing them.
This setup never squeked until last fall I swapped the rear brakes to disc and the rear end stayed in the air for 2 or 3 days.
Could it be the struts alone making the noise? Any opinions would be appreciated.
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 04-22-2006, 03:35 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
does the suspension squeak when you get in/out of the car? if it is, then it's the springs rubbing as they compress/decompress
try spraying down your entire suspension with deep pentrating lubricant
you can get them in a can, and they do wonders- all my squeaks are gone
HaHa
Old 04-22-2006, 05:26 PM   #3 (permalink)
Rubbing against what??? When you say to spray the entire suspension, are you talking about the springs? There isn't that much back there. I just can't picture what any sort of spray would do to help here.
Old 04-22-2006, 06:35 PM   #4 (permalink)
TN Pussy Man
just the coils rubbing against each other rubbing agains the sides of the mounts
this stuff does wonders- try it!
HaHa
1996 Corolla rear lip or rear bumper (AE102) Jaspher Archived Corolla threads 2 11-24-2006 02:10 PM
Problems with the rear suspension. just2asian Camry & Solara Lounge 13 02-22-2006 11:41 PM
2006 RAV4 Features & Pricing [Canadian Spec] rolla-XRS Toyota News 19 01-03-2006 11:37 AM
Rear Fenders touching tires taimurakhter Camry & Solara Lounge 17 10-23-2005 12:21 PM
rear brakes, disk or drum? chris-k Camry & Solara Lounge 2 08-21-2002 01:23 PM
