Alternator Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 06:52 PM   #1 (permalink)
View wilsonca's Photo Gallery
Alternator Help
I have a 2002 4-cylinder camry. I'm having some trouble getting the alternator out of the car. I have removed the two mounting bolts, but there seems to be a sleeve that the top bolt screws into that is still holding the assembly in place. The alternator is free to rotate about the point where the top mounting bolt was.
If anyone has experience with this, please let me know if there is a trick to getting the assmebly out of the car. Thanks in advance!!
wilsonca is offline   Reply With Quote
Old 04-22-2006, 07:51 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Just wiggle and pull on the alternator. It'll come loose.
"Skoolin' the unlearned!"
Old 04-22-2006, 11:39 PM   #3 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
yea, its just very snug. i had trouble with mine too. watch your plug when doing it too, mine fell in between the alt and manifold while i was wiggling and cracked it...=(
wd-40 would help
WhiteRabbit is offline   Reply With Quote
Old 07-07-2006, 08:54 PM   #4 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Exclamation
You can apply a little Anti-Sieze to the area before reassembly. This will ensure that you won't have the problem the next time you remove the alternator.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 07-07-2006, 09:00 PM   #5 (permalink)
View Novice_cardude's Photo Gallery
Those do go on there really snug. Usually i take a prybar to it, and very gently pry up or to the side. It'll move just enough to break it loose, then pull it out.
Good luck!
Novice_cardude is offline   Reply With Quote
