Foul odor coming from ac - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 10:56 PM   #1 (permalink)
View Joel930's Photo Gallery
Lately, I've been noticing a rather foul odor coming emitting from my ac vents. I changed my cabin filter a while ago so its not that.
Joel930 is offline   Reply With Quote
Old 04-22-2006, 11:12 PM   #2 (permalink)
Alloy's Avatar
View Alloy's Photo Gallery
My car has the same problem too, my guess would be moisture in there. Did you use the recirrulation button? Anyone has more knowledge on this?
:creature:07 Magnetic Grey Metallic SE
Alloy is offline   Reply With Quote
Old 04-22-2006, 11:18 PM   #3 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
I've had this on my other car, Passat. Seems like moiture has gotten in the system and mold or mildew set in. Is that the type of smell you are getting, a moldy mildew smell?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 04-22-2006, 11:29 PM   #4 (permalink)
Alloy's Avatar
haha, interesting. I had a Passat b4 the Camry and I had the same problem too. I dunno how should a moldy smell be like, but I thought there's some kind of dead animals (of coz that' s not the case). Anyway, the odour only only comes during summer time espcially after AC is used and when I switch to "fan". I guess is the warm-cold factor that cause all the moisture. I actually talked to the dealer about it, they said is a normal problem. I can buy some spray at CanadianTire for such kinda problem, but they said after a while, the odour will come back.
Old 04-22-2006, 11:52 PM   #5 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
one way to get rid of it is using lysol mildew spray. turn on the car open all doors/windows. Fan on max, heater on max. you will rotate throug each of the vents. You will then spray a ton of that lysol into the fresh air intake vents. Run until the smell of lysol dies down. This can be a while but it is effective most of the time.
For future reference, make sure you leave your car in Fresh air mode before you turn it off. it is best to turn off the ac for about 1 minute before you park the car, and just have the fan on with the fresh vents open. This minimizes moisture gathering in the vents.
nodrogkam is offline   Reply With Quote
Old 04-22-2006, 11:52 PM   #6 (permalink)
View AutoBox's Photo Gallery
^yeah that smell is a common nuisance in our cars. a cheaper alternative to the sprays at auto parts store is to buy an aerosol can of original Lysol spray.
turn on your car, open all the windows and doors. turn your temp. selector to far left cold, fan on highest speed and set it to draw in fresh air. spray some Lysol into the exterior vents that draw in the outside air. (the vents are under the wiper blades, at the bottom of the windshield.) after a few bursts, turn on your a/c for a couple minutes. then turn off the a/c and repeat with the Lysol. it freshens the evaporator in the a/c system.
but its not a permanant solution so you may need to repeat the process depending on how much you use your a/c and when the smell returns. oh and you will want to cover your front seats and console with a sheet or cloth (especially if you have leather) because the Lysol will mist into the cars interior.
damn beaten ha
AutoBox is offline   Reply With Quote
Old 04-23-2006, 12:07 AM   #7 (permalink)
Alloy's Avatar
Thank you. Nodrogkam, for fresh air intake vent, do you mean those under the wiper blades, at the buttom of the windshield like AutoBox suggested? Don't even need to open the hood right? Is the Lysol mildew spray the same as those at the air fresher aisle of WalMart, or it's at the automotive aisle?
Old 04-23-2006, 12:11 AM   #8 (permalink)
Any of these will do just fine.
The vents are exactly where i described them ^
Old 04-23-2006, 12:14 AM   #9 (permalink)
Alloy's Avatar
Great, that would be easy.
Old 04-23-2006, 12:36 AM   #10 (permalink)
yeah the Lysol isn't that expensive, make sure you pick a scent that is pleasing to you because the Lysol smell will linger for a while unless you use another air freshner afterwards. i like the clean linen one myself it has more of an air freshner smell than a disinfectant smell.
of coarse don't breathe it in when your spraying and do not get in the car immediatly after spraying it into the vents. give it a minute to go through the vents...the fumes/spray can be harmful to your lungs and throat if inhaled.
Old 04-23-2006, 12:48 AM   #11 (permalink)
Alloy's Avatar
okay. really appreciate that.
Old 04-23-2006, 01:01 AM   #12 (permalink)
good suggestions folks.
Thanks
Old 04-23-2006, 01:11 AM   #13 (permalink)
View leasaunce's Photo Gallery
ok..
use that spray/cleaner thing.
I had this problem last year, I didnt use any spray cleaner though. All i did was let fresh air in after each time i turn on the A/C
(A/C off, Fresh air in, FAN SPEED HIGH for 20sec, then u should be fine )
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 04-23-2006, 09:50 AM   #14 (permalink)
nodrogkam's Avatar
LOL i wish i was smart enough to get a fresh scent...i didnt use an arisol spray can i used a spray bottle style. I think it was like a bathroom mildew cleaner from lysol i used. Huge ass bottle i didnt need but i still used half in my minivan.
Just make sure the fans are on max and the air is on fresh and commence spraying! I'd let the stuff run for AT LEAST 5 minutes before you even attempt to get near the insideof your car.
AC performance humidity dependent, need help ruoknow Camry & Solara Lounge 8 04-28-2006 03:53 PM
'95 AC Question Jevid Archived Corolla threads 0 08-30-2005 10:30 AM
'02 Tacoma AC Question shane28462 1st Generation (1995.5–2004) 0 07-10-2005 01:48 AM
'00 4Runner AC issue nspringer 4Runner Lounge 1 07-29-2004 01:24 PM
MK3 TURBO!, No Heater, No AC, IM STUMPED!!! seiffert Supra Forum 0 04-24-2004 01:36 PM
