Rattle in trunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 11:59 PM   #1 (permalink)
98 T100 V6 4x2 Ext Cab
nunyadamnbiz's Avatar
View nunyadamnbiz's Photo Gallery
Question Rattle in trunk
Ok i can hear the struts rattling in the back when i hit bumps big or small, i've had them checked out and they were just replaced last yr. and about 25K ago, they say that they are fine and everything is normal, just deal with it and turn up the radio, any suggestions, and how hard is it to put on tower bars on the front and rear, does it help with the pitch and roll alot any help would be grateful and i'm glad i found a NICE Toy forum
nunyadamnbiz is offline   Reply With Quote
Old 04-23-2006, 12:52 AM   #2 (permalink)
tC
View 95camguy's Photo Gallery
check ur sway bar bushings... they're probably shot.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 04-23-2006, 12:53 AM   #3 (permalink)
View caveman017's Photo Gallery
how do you actually check them?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 04-23-2006, 01:34 AM   #4 (permalink)
tC
u can search this topic... its been discussed. search "rear sway bar bushings" or "trunk rattle"
07 tC MT
-TRD RSB
-TRD Exhaust
Old 04-23-2006, 02:25 AM   #5 (permalink)
i personally did not check them i brought them to a local chain that put on the struts, how would i go about checking the bushings, not good with suspension thats for sure
thanks for the help fellas, im searchin now
Old 04-23-2006, 09:03 AM   #6 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
strut mounts...
skewe is offline   Reply With Quote
Old 04-23-2006, 03:55 PM   #7 (permalink)
Gameroom cash: $304355
"how would i go about checking the bushings, not good with suspension thats for sure"
Jack up the rear end of the car. Support it safely on jack stands. Now crawl under the car and grab hold of the swaybar. Try to move it from side to side. If you can move it side to side with only slight pressure, the swaybar bushings are shot and need to be replaced.
Mike
Old 04-23-2006, 06:58 PM   #8 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
Get the sway bar bushes replaced, it seems nearly every GEN3 owner will have this problem at some stage.
Should cost you under $100.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
DIY sort of Electronic Trunk Pop Anshu General Discussion 3 06-17-2005 10:30 AM
stopping my trunk rattle... Hamsterman Audio, Video, and Security - Tech 8 05-28-2005 09:47 AM
Rattle in Trunk MoldySpore Camry & Solara Lounge 9 05-16-2005 11:07 PM
subs causing trunk to rattle miami54dolphin Audio, Video, and Security - Tech 5 10-07-2004 08:32 AM
Sub makes trunk rattle....duh DrtySthV6SE Camry & Solara Lounge 10 06-13-2002 11:58 PM
