5SGTE Timing problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2006, 09:49 PM   #1 (permalink)
View draco12369's Photo Gallery
Hi I got a 5SFE block with a 3SGTE head on it. I am attempting to turn it on but it wont turn on. I am running a standalone ecu on the car that is wired right. I get spark and fuel. When i crank the car over it sounds like that car has no compression. I am using a 3sgte timing belt with the tenssioner, 3sgte oil pump, 5sfe water pump. I will get my compression tester back tommarow and check to make sure i got compressionbut in the mean time any suggestions would be greatly appreciated.
I dont suffer from insanity i enjoy every minute of it.
draco12369 is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Timing questions tracyf Camry & Solara Lounge 11 03-23-2006 10:28 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Please HELP!! '85 Supra charging problem......an advanced problem... sbarc Hardcore Tech and Competition 5 07-14-2005 07:10 PM
odd vibration problem niju321 Camry & Solara Lounge 3 07-07-2005 12:15 PM
